This USB-C multiport video adapter offers a portable solution for connecting your USB Type-C laptop to a VGA, DVI, HDMI or Mini DisplayPort (mDP) display.
Avoid the hassle of carrying different adapters, with a 4-in-1 USB-C monitor adapter. With VGA, DVI, HDMI and mDP output, you can connect your laptop to any display using this multiport adapter.
The adapter features a magnetic retainer that guides the breakout cable into place for quick, secure portability. With a durable aluminum enclosure, the adapter can withstand being carried in your travel bag.
The HDMI and mDP outputs on this USB-C video adapter support UHD resolutions up to 4K 60Hz, while the VGA and DVI outputs support HD resolutions up to 1920 x 1200.
The USB-C adapter has a Space Gray housing and built-in USB-C cable designed to match your Space Gray MacBook, or MacBook Pro. The adapter is compatible with USB-C DP Alt Mode devices.
The adapter is also available with 4K 30Hz HDMI resolution support, in three colours: Space Gray (CDPVDHDMDPSG), Rose Gold (CDPVDHDMDPRG) and Silver (CDPVGDVHDMDP), so you can choose an adapter that matches your laptop or your colour preference.
- StarTech.com USB C Multiport Video Adapter with HDMI, VGA, Mini DisplayPort or DVI, USB Type C Monitor Adapter to HDMI 2.0 or mDP 1.2 (4K 60Hz), VGA or DVI (1080p), Space Gray Aluminum - 4-in-1 USB-C Converter - adapter - Mini DisplayPort / HDMI / DVI / USB / VGA
- Cable
- Adapter - Mini DisplayPort / HDMI / DVI / USB / VGA
- Max Output Resolution
- 4096 x 2160 - 60 Hz
- Space grey
- Connectors
- 24 pin USB-C - male (input)
- Connectors (Second End)
- HDMI - female (output) , Mini DisplayPort - female (output) , HD-15 (VGA) - female (output) , DVI-I - female (output)
- Displayport 1.2/Thunderbolt 3
- Active converter, 1920 x 1200 (WUXGA) support 60Hz (DVI and VGA), 4K24Hz (4096 x 2160) support (HDMI), 4K60Hz (3840 x 2160) support (HDMI), 4K60Hz (4096 x 2160) support (mDP)
- 3-year warranty
- Cable Type
- Adapter active converter, 1920 x 1200 (WUXGA) support 60Hz (DVI and VGA), 4K24Hz (4096 x 2160) support (HDMI), 4K60Hz (3840 x 2160) support (HDMI), 4K60Hz (4096 x 2160) support (mDP)
- Interface Supported
- Aluminium casing, DisplayPort Alternate Mode support, 7.1 channel Surround Sound
- Space grey
Adapters & Converters
- 4096 x 2160
- Refresh Rate
- 60 Hz
- OS Required
- Apple MacOS, Linux, Microsoft Windows, Google Chrome OS
- Connectors
- 19 pin HDMI Type A - female (output) , Mini DisplayPort - female (output) , 15 pin HD D-Sub (HD-15) - female (output) , 24+5 pin combined DVI - female (output)
- FCC, RoHS, HDCP 2.2, HDCP 1.4
- Limited warranty - 3 years
StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.74 |
StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter | In Stock | £20.33 |
StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £3.73 |
StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £11.94 |
StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M | In Stock | £19.68 |
StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter | In Stock | £9.28 |
StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black | In Stock | £31.58 |
StarTech.com mDP to HDMI or VGA Converter | In Stock | £8.35 |
StarTech.com mDP to HDMI or VGA Converter | In Stock | £13.32 |
StarTech.com USB C to VGA and HDMI Adapter - Aluminum - USB-C Multiport Adapter - 6" Built-In Cable | In Stock | £28.26 |
StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter | In Stock | £19.10 |
StarTech.com USB C Multiport Video Adapter - VGA or Mini DisplayPort - HD | In Stock | £12.85 |
StarTech.com USB C Multiport Video Adapter - HDMI or DisplayPort - HDR 4K60 - Display Adapter | In Stock | £30.67 |
StarTech.com USB C Multiport Video Adapter - HDMI or Mini DisplayPort -HDR 4K Display Adapter | In Stock | £16.09 |
StarTech.com USB C to HDMI Adapter 4K 60Hz | In Stock | £12.35 |
StarTech.com USB C Video Adapter 4K 60Hz | In Stock | £40.78 |
