Enable quick access to four 2.5"/3.5" SATA HDD over USB 3.0. The SATDOCK4U3 USB 3.0 4-Bay SATA Hard Drive Docking Station is a convenient, time-saving storage solution for 2.5-inch and 3.5-inch SATA hard drives (HDD) and solid state drives (SSD), that enables you to connect up to 4 SATA drives through a single host connection, while controlling the power status (on/off) of each individual drive independently from the rest.
The hard drive docking station features SuperSpeed USB 3.0 connectivity (backward compatible with USB 2.0), which supports data transfer rates up to 10x faster than USB 2.0. The docking station also offers dual built-in, variable-speed 60mm cooling fans with manual control (including off).
Double the value of this hard drive docking station, by using a SATA to IDE hard drive adapter (SAT2IDEADP), which enables you to use any 2.5 or 3.5in IDE hard drive in a SATA hard drive dock slot.
- StarTech.com 4 Bay USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD - HDD docking station - SATA 3Gb/s - USB 3.0
- HDD docking station - external
- Bays
- 4
- Bus Type
- USB 3.0
- Black
- Expansion Bays
- 4 x hot-swap - 2.5" / 3.5" shared
- Hard Drive Form Factor Compatibility
- 2.5", 3.5"
- Power indicator
- Interface
- SATA 3Gb/s
- Data Transfer Rate
- 3 Gbit/s
- Supported Devices
- Hard drive
- Product Material
- Plastic
- Power Source
- Included AC adapter
- System Requirements
- Linux, Microsoft Windows 2000, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
- 17.3 cm x 29.1 cm x 9.5 cm
- 1.1 kg
- 2-year warranty
- Bays
- 4
- 2.5", 3.5"
- Host Bus
- USB 3.0
- Product Material
- Plastic
- Black
- Power indicator
Storage Controller
- Interface
- SATA 3Gb/s
- 3 Gbit/s
- Supported Devices
- Hard drive
- Bays
- 1 x SATA 3Gb/s - SATA power , 4 x SATA 3Gb/s - SATA
- Connections
- 1 x USB 3.0 - 9 pin USB Type A
- Included Accessories
- Power supply
- Cables Included
- 1 x USB cable - external
- Tested with up to 4TB 5400 RPM 3.5” hard drives, tested with up to 1TB 5400 RPM 2.5” hard drives
- Plug and Play, FCC, RoHS
- Power Source
- Power adapter
- OS Required
- Limited warranty - 2 years
- 17.3 cm
- 29.1 cm
- 9.5 cm
- 1.1 kg
- 5 °C
- 80 °C
- 8 - 90%
