StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails
Quicklinx: 7X1FWS00 Mfr#: UNIRAILS3U
Product Type: Rack rail
Hurry, only 3 left in stock!
£77.01 ex VAT
£92.41 inc VAT
Mount 19" servers or networking hardware in any standard rack with these universal, adjustable depth 3U rack rails. The UNIRAILS3U 3U Fixed 19-inch Server Rack Rails (Adjustable Depth, Universal) enables you to fit non-rack mountable equipment at weight capacities up to 97kg (215lbs.) into standard 19-inch racks. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Featuring sturdy, cold-rolled steel construction, adjustable depth configurations for varying rack sizes, horizontal equipment supports, and multiple mounting hole patterns to secure your equipment, this universal rack rail kit makes mounting your non-rackmount equipment quick and easy.
  • Turn non-rackmount equipment into 3U rackmount hardware
    These rack rails add rackmount functionality to your non-rackmount gear, by cradling your equipment in an open frame supported by three sturdy crossbars. You can mount your non-rackmount equipment by mounting the rails to your server rack and placing your equipment on the undercarriage. For equipment that already features mounting holes, the rails also feature multiple mounting patterns to secure your equipment, for an added level of security.
  • Universal design mounts to almost any 19" server rack
    Adhering to the EIA-310 standard for 19" rackmount equipment, these mounting rails are universally compatible with 19" server racks. The depth is adjustable for a variety of rack sizes and configurations. Plus, there is a rear cable management panel that's removable for additional customization.
  • Maximum durability
    To ensure your equipment is secure, these mounting rails feature cold-rolled steel construction. The durable design can support a weight load of up to 100 lb (45 kg). The UNIRAILS3U is backed by a lifetime StarTech.com warranty with free technical support.
StarTech.com 3U Universal Server Rack Rails - TAA Compliant Fixed Mounting Rails - 19" Adjustable Depth Rack Mount Rails (UNIRAILS3U) - rack rail - 3U
Rack rail
Rack Size
19"
Height (Rack Units)
3U
Product Material
Steel
46.5 cm x 48.1 cm x 13.2 cm
3.8 kg
Adjustable depth
P/N: 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK960CP, RKQMCAB12, RKWOODCAB12
Rack rail
Product Material
Steel
Rack Size
19"
Height (Rack Units)
3U
46.5 cm
48.1 cm
13.2 cm
3.8 kg
Weight Limit
97 kg
Mounting Kit
Included
Adjustable depth
UL, RoHS
Limited warranty: - lifetime
P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK960CP, RKQMCAB12, RKWOODCAB12
7X1F StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £94.63
7X1F StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
7X1F StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
7X1F StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £86.88
7X1F StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £62.88
7X1F StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £72.65
7X1F StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £80.55
