StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg
Quicklinx: 7P3LWS00 Mfr#: UNISLDSHF19
Product Type: Rack shelf, Rack shelf
£86.88 ex VAT
£104.25 inc VAT
Increase peripheral and equipment accessibility with this vented sliding cabinet shelf. The UNISLDSHF19 19in Vented Adjustable Mounting Depth Sliding Server Rack Cabinet Shelf offers a simple way to install non rack mountable equipment into a server cabinet or open server rack. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Offering a weight capacity of up to 50 lbs (22.7 kg), the sliding rack shelf features a ventilated, cold-rolled steel shelf on two locking adjustable rails which allow the shelf to be installed into cabinets or racks with mounting depths from 20in (510mm) to 30in (744mm). The locking feature locks the shelf 3/4 of the way out, preventing the shelf from accidentally falling out of the rack or sliding back in before maintenance is complete.
  • Durable construction
    Made from cold-rolled steel, this rack shelf offers support for heavy equipment while ensuring longevity.
  • Adjustable depth
    The depth of the shelf can be adjusted from 20 to 30 inches, allowing it to fit various rack setups and accommodate equipment of different sizes.
  • Secure design
    With a lockable feature, this shelf ensures that equipment remains stable and secure during operation.
  • Effective ventilation
    The vented design aids in airflow, helping to keep equipment cool and functioning efficiently.
  • Standard fit
    Designed for 19-inch racks, this 2U shelf integrates easily into existing server setups without complications.
StarTech.com Server Rack Shelf - 2U - 20 to 30in Adjustable Mounting Depth - Vented - Server Rack Cabinet Shelf - 24in Deep - rack shelf - 1U
Rack shelf
Rack Size
19"
Height (Rack Units)
1U
Product Material
Cold-rolled steel
Sliding, adjustable depth, lockable, vented
P/N: 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKHD, RK1219SIDEM, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK819SIDEM, RK960CP, RKQMCAB12
Rack shelf
Product Material
Cold-rolled steel
Rack Size
19"
Height (Rack Units)
1U
P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1219SIDEM, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK819SIDEM, RK960CP, RKQMCAB12
7P3L StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £94.63
7P3L StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £79.45
7P3L StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
7P3L StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.71
7P3L StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £86.88
7P3L StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £62.88
7P3L StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £72.65
7P3L StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £77.01
7P3L StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £81.75
7P3L StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters In Stock £514.25
