Turn a laptop USB-C port into three USB Type-A ports (5Gbps) and one GbE port, plus power and charge your laptop. This 3-port USB 3.0 hub with Gigabit Ethernet couples your USB peripheral and RJ45 network connections into a single convenient hub, with support for USB Power Delivery. This means that you can power and charge your laptop through its USB-C port while simultaneously powering the hub.
With its integrated USB Type-C cable and small-footprint design, this versatile hub offers a perfectly portable solution for connecting devices that require traditional USB Type-A ports to your USB-C or Thunderbolt 3 equipped computer.
If your USB-C equipped laptop or MacBook is missing the ports you need, this hub can help. The versatile USB 3.0 hub gives you access to not only your USB peripheral devices but also a wired internet connection. It offers a Gigabit Ethernet port, so you can connect to a network in locations where Wi-Fi is unreliable or unavailable.
This USB hub is multi-platform compatible, which means it will work with a wide range of USB-C laptops that use a USB-C power adapter. It also works with a range of operating systems such as Windows, macOS, Linux and Chrome OS . It automatically installs once you connect it to your laptop, so you can be up and running in seconds.
This USB-C 3.0 hub supports USB Power Delivery 2.0, so instead of carrying multiple cables and power adapters, you can use your laptop's USB-C power adapter to power both your laptop and the hub. By using just a single power adapter instead of two, you can eliminate clutter and hassle when you work.
With its compact and rugged design, you can take this portable USB 3.0 hub anywhere you go. Because it's so compact, it's easy to tuck into your laptop bag and only takes up a small amount of desk space when you connect it to your workstation. For portable applications, having the integrated host (USB-C) cable means one less thing to remember to carry with you.
Merge two vital port types into one stylish hub
If your USB-C equipped laptop or MacBook is missing the ports you need, this hub can help. The versatile USB 3.2 Gen 1 hub gives you access to not only your USB peripheral devices but also a wired internet connection. It offers a Gigabit Ethernet port, so you can connect to a network in locations where Wi-Fi is unreliable or unavailable. -
Connect your USB devices in seconds
This USB hub is multi-platform compatible, which means it will work with a wide range of USB-C laptops that use a USB-C power adapter. It also works with a range of operating systems such as Windows , macOS, Linux and Chrome OS . It automatically installs once you connect it to your laptop, so you can be up and running in seconds. -
Carry fewer cables and power adapters
This USB-C 3.2 Gen 1 hub supports USB Power Delivery 2.0, so instead of carrying multiple cables and power adapters, you can use your laptop's USB-C power adapter to power both your laptop and the hub. By using just a single power adapter instead of two, you can eliminate clutter and hassle when you work. -
Take it with you wherever you go
With its compact and rugged design, you can take this portable USB 3.2 Gen 1 hub anywhere you go. Because it's so compact, it's easy to tuck into your laptop bag and only takes up a small amount of desk space when you connect it to your workstation. For portable applications, having the integrated host (USB-C) cable means one less thing to remember to carry with you. The HB30C3AGEPD is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com 3 Port USB-C Hub with Gigabit Ethernet & 60W Power Delivery Passthrough Laptop Charging, USB-C to 3x USB-A (USB 3.0 SuperSpeed 5Gbps), USB 3.1/USB 3.2 Gen 1 Type-C Adapter Hub - Windows/macOS/Linux (HB30C3AGEPD) - hub - 3 ports
- Hub - 3 ports
- Subtype
- USB
- Ports
- 3 x SuperSpeed USB 3.0 + 1 x 10/100/1000
- Jumbo Frame Support
- 9000 bytes
- Flow control, auto-negotiation, WOL, auto-uplink (auto MDI/MDI-X), full duplex mode, USB powered, Energy Efficient Ethernet, priority encoding, tagged VLAN, UASP
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, USB 1.1, USB 2.0, USB 3.0
- 4.1 cm x 9.5 cm x 1.7 cm
- 44.9 g
- Black
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Linux Kernel 2.6.25 or later, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.7 - 10.15, Apple macOS 11.0, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- 2-year warranty
- Hub - 3 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- 9000 bytes
- Processor
- X VIA Labs / Realtek VL100 / VL812 / RTL8153
- 3 x USB 3.0 output Type A , 1 x 1000Base-T RJ-45 , 1 x USB-C (power only) , 1 x USB 3.0 input Type C
- Black
- Plug and Play, FCC, RoHS
- OS Required
- 4.1 cm
- 9.5 cm
- 1.7 cm
- 44.9 g
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable | In Stock | £39.78 |
StarTech.com Rugged Hard Drive Enclosure | In Stock | £34.04 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £7.59 |
StarTech.com 4 Port USB 3.0 Hub - USB-C Hub | In Stock | £30.59 |
StarTech.com 1m USB 2.0 USB-C to USB-A Cable | In Stock | £10.31 |
StarTech.com 3Pt Portable USB 3.0 Hub + GbE | In Stock | £34.00 |
StarTech.com USB-C to Gigabit Adapter | In Stock | £36.31 |
StarTech.com 3m 10ft USB 3.0 A to A Cable | In Stock | £7.29 |
StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop | In Stock | £43.58 |
StarTech.com 6ft USB-C to A Cable - USB 2.0 | In Stock | £11.87 |
StarTech.com 4-Port USB-C Hub - USB 3.1 | In Stock | £34.22 |
StarTech.com 4-Port USB 3.0 Hub with On/Off | In Stock | £24.24 |
StarTech.com 3-Port USB-C Hub, 2.5GbE, PD | In Stock | £54.63 |
StarTech.com USB-C/USB-A Hub - GbE - RS232 | In Stock | £64.25 |
