StarTech.com 4-Port USB 3.0 Hub with On/Off
Quicklinx: DQZ4WS00 Mfr#: HB30A4AIB
Type: USB Hub
Interface: USB
Speed: 5Gbps
Ports: 4
Form Factor: External
£26.33 ex VAT
£31.59 inc VAT
This portable USB 3.0 hub gives you an easy way to add four USB 3.0 Type-A ports to your laptop, with individual power switches to save power. The USB port expander plugs easily into your laptop's USB Type-A port. Plus, it's bus-powered for easy portability.
Use your existing USB 3.0 devices such as flash drives, mouse, keyboard and external hard drives. The 4-port USB 3.0 hub expands your computer's USB Type-A port into four USB 3.0 (Type-A) ports, and it's backward compatible with your older USB 2.0 devices. (USB 3.0 is also known as USB 3.1 Gen 1.)
Each port on the USB 3.0 hub has its own power switch so you can turn off devices when they're not in use. That means you can better manage power consumption for your USB devices, without having to physically disconnect the device or cable.
With its compact, lightweight design, this hub is perfect for portable use. The versatile USB to USB hub is bus-powered, with no need for an external power adapter. You can travel lighter with fewer cables to carry with you.
The 4-Port USB 3.0 hub installs automatically when you connect it to your laptop, so you can be up and running in seconds.
StarTech.com 4 Port USB 3.0 Hub, USB-A to 4x USB 3.0 Type-A with Individual On/Off Port Switches, SuperSpeed 5Gbps USB 3.1/USB 3.2 Gen 1, USB Bus Powered, Portable, 9.8" Attached Cable - Windows/macOS/Linux (HB30A4AIB) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB 3.1 Gen 1
USB powered, on/off switches
USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 1
3.49 cm x 8.5 cm x 1.92 cm
50 g
Apple MacOS, Linux, Microsoft Windows
P/N: HB30C4AIB
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB 3.1 Gen 1
X VIA Labs VL817
Status Indicators
4 x USB 3.1 Gen 1 Type A
1 x USB 3.1 cable - 25 cm
FCC, RoHS, UASP (USB Attached SCSI Protocol)
3.49 cm
8.5 cm
1.92 cm
50 g
Shipping Weight
58 g
55 °C
20 - 80% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
P/N: HB30C4AIB
DQZ4 StarTech.com 1m Blue SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.53
DQZ4 StarTech.com 1m USB 3 Cable Right Angle BK In Stock £6.63
DQZ4 StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £8.94
DQZ4 StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £10.90
DQZ4 StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £6.86
DQZ4 StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £7.70
DQZ4 StarTech.com 6in USB 3.0 Extension Cable In Stock £5.31
DQZ4 StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £9.82
DQZ4 StarTech.com 4 Port USB 3.0 Hub - USB-C Hub In Stock £34.22
DQZ4 StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop In Stock £57.55
DQZ4 StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White In Stock £42.64
DQZ4 StarTech.com 4 Port USB C Hub - C to C & A In Stock £29.51
DQZ4 StarTech.com 4 Port USB-C Hub - C to C & A In Stock £40.72
DQZ4 StarTech.com 7 Port USB C Hub - C to C & A In Stock £82.41
DQZ4 StarTech.com 4-pt USB Hub with On/Off Switches In Stock £49.12
DQZ4 StarTech.com 7-pt USB Hub with On/Off Switches In Stock £70.57
Type: USB Hub
Interface: USB
Speed: 5Gbps
Ports: 4
