StarTech.com 3PT USB 3.0 C Hub + GbE PD 2.0
Quicklinx: CTW6WS00 Mfr#: HB30C3AGEPD
Type: USB Hub
Interface: USB 3.1 Type C
Speed: 5Gbps
Ports: 3
Form Factor: External
£46.96 ex VAT
£56.35 inc VAT
Turn a laptop USB-C port into three USB Type-A ports (5Gbps) and one GbE port, plus power and charge your laptop. This 3-port USB 3.0 hub with Gigabit Ethernet couples your USB peripheral and RJ45 network connections into a single convenient hub, with support for USB Power Delivery. This means that you can power and charge your laptop through its USB-C port while simultaneously powering the hub.
With its integrated USB Type-C cable and small-footprint design, this versatile hub offers a perfectly portable solution for connecting devices that require traditional USB Type-A ports to your USB-C or Thunderbolt 3 equipped computer.
If your USB-C equipped laptop or MacBook is missing the ports you need, this hub can help. The versatile USB 3.0 hub gives you access to not only your USB peripheral devices but also a wired internet connection. It offers a Gigabit Ethernet port, so you can connect to a network in locations where Wi-Fi is unreliable or unavailable.
This USB hub is multi-platform compatible, which means it will work with a wide range of USB-C laptops that use a USB-C power adapter. It also works with a range of operating systems such as Windows, macOS, Linux and Chrome OS . It automatically installs once you connect it to your laptop, so you can be up and running in seconds.
This USB-C 3.0 hub supports USB Power Delivery 2.0, so instead of carrying multiple cables and power adapters, you can use your laptop's USB-C power adapter to power both your laptop and the hub. By using just a single power adapter instead of two, you can eliminate clutter and hassle when you work.
With its compact and rugged design, you can take this portable USB 3.0 hub anywhere you go. Because it's so compact, it's easy to tuck into your laptop bag and only takes up a small amount of desk space when you connect it to your workstation. For portable applications, having the integrated host (USB-C) cable means one less thing to remember to carry with you.
  • Merge two vital port types into one stylish hub
    If your USB-C equipped laptop or MacBook is missing the ports you need, this hub can help. The versatile USB 3.2 Gen 1 hub gives you access to not only your USB peripheral devices but also a wired internet connection. It offers a Gigabit Ethernet port, so you can connect to a network in locations where Wi-Fi is unreliable or unavailable.
  • Connect your USB devices in seconds
    This USB hub is multi-platform compatible, which means it will work with a wide range of USB-C laptops that use a USB-C power adapter. It also works with a range of operating systems such as Windows , macOS, Linux and Chrome OS . It automatically installs once you connect it to your laptop, so you can be up and running in seconds.
  • Carry fewer cables and power adapters
    This USB-C 3.2 Gen 1 hub supports USB Power Delivery 2.0, so instead of carrying multiple cables and power adapters, you can use your laptop's USB-C power adapter to power both your laptop and the hub. By using just a single power adapter instead of two, you can eliminate clutter and hassle when you work.
  • Take it with you wherever you go
    With its compact and rugged design, you can take this portable USB 3.2 Gen 1 hub anywhere you go. Because it's so compact, it's easy to tuck into your laptop bag and only takes up a small amount of desk space when you connect it to your workstation. For portable applications, having the integrated host (USB-C) cable means one less thing to remember to carry with you. The HB30C3AGEPD is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com 3 Port USB-C Hub with Gigabit Ethernet & 60W Power Delivery Passthrough Laptop Charging, USB-C to 3x USB-A (USB 3.0 SuperSpeed 5Gbps), USB 3.1/USB 3.2 Gen 1 Type-C Adapter Hub - Windows/macOS/Linux (HB30C3AGEPD) - hub - 3 ports
Hub - 3 ports
Subtype
USB
Ports
3 x SuperSpeed USB 3.0 + 1 x 10/100/1000
Jumbo Frame Support
9000 bytes
Flow control, auto-negotiation, WOL, auto-uplink (auto MDI/MDI-X), full duplex mode, USB powered, Energy Efficient Ethernet, priority encoding, tagged VLAN, UASP
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, USB 1.1, USB 2.0, USB 3.0
4.1 cm x 9.5 cm x 1.7 cm
44.9 g
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Linux Kernel 2.6.25 or later, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.7 - 10.15, Apple macOS 11.0, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Hub - 3 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Jumbo Frame Support
9000 bytes
X VIA Labs / Realtek VL100 / VL812 / RTL8153
3 x USB 3.0 output Type A , 1 x 1000Base-T RJ-45 , 1 x USB-C (power only) , 1 x USB 3.0 input Type C
Plug and Play, FCC, RoHS
4.1 cm
9.5 cm
1.7 cm
44.9 g
45 °C
10 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
CTW6 StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable In Stock £39.78
CTW6 StarTech.com Rugged Hard Drive Enclosure In Stock £34.04
CTW6 StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.59
CTW6 StarTech.com 4 Port USB 3.0 Hub - USB-C Hub In Stock £30.59
CTW6 StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £10.31
CTW6 StarTech.com 3Pt Portable USB 3.0 Hub + GbE In Stock £34.00
CTW6 StarTech.com USB-C to Gigabit Adapter In Stock £36.31
CTW6 StarTech.com 3m 10ft USB 3.0 A to A Cable In Stock £7.29
CTW6 StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop In Stock £43.58
CTW6 StarTech.com 6ft USB-C to A Cable - USB 2.0 In Stock £11.87
CTW6 StarTech.com 4-Port USB-C Hub - USB 3.1 In Stock £34.22
CTW6 StarTech.com 4-Port USB 3.0 Hub with On/Off In Stock £24.24
CTW6 StarTech.com 3-Port USB-C Hub, 2.5GbE, PD In Stock £54.63
CTW6 StarTech.com USB-C/USB-A Hub - GbE - RS232 In Stock £64.25
Type: USB Hub
Speed: 5Gbps
Ports: 3
