StarTech.com 3Pt Portable USB 3.0 Hub + GbE
Quicklinx: BST8WS00 Mfr#: ST3300G3UA
Type: USB Hub
Interface: SuperSpeed USB 3.0
Speed: [N/A]
Ports: 3
Form Factor: External
13 In Stock
£33.70 ex VAT
£40.44 inc VAT
Add three USB 3.0 ports (5Gbps) and a GbE port to your MacBook, using this silver, Apple style hub with an extended-length cable. Here's a must-have accessory for your MacBook. This portable USB 3.0 hub merges your USB peripheral and RJ45 network connections into a single, convenient combination hub. It gives you two vital connection types that are often missing from modern, port-limited laptops.
This silver, sandblasted USB hub matches the finish of your MacBook, and because it features a solid-aluminum casing that's both lightweight and rugged, it's perfect for travel usage. It also integrates a lengthier, 27 cm (10.5 in) cable, so you have the flexibility to place the hub, your devices, and your network connection, exactly where you need them.
This high-quality, Apple style USB hub features a Gigabit Ethernet port, giving you an easy way to expand your MacBook connectivity. And because the hub integrates a Gigabit Ethernet port, you can add wired network connectivity to your laptop in a location where Wi-Fi is unreliable or unavailable.
The hub's built-in USB cable has sufficient length to reach your laptop's USB 3.0 port, regardless of where the port is located.
Plus, the stylish hub features three USB 3.0 (also known as USB 3.1 Gen 1) ports in a compact housing. And, its silver, sandblasted finish provides a unique and trendy look when compared to traditional hubs.
The hub features a rugged yet lightweight housing, so there's no need to sacrifice dependability for portability. With its compact, USB-powered design and a built-in USB cable, you can tuck the combination hub neatly into your travel bag, and avoid the nuisance of carrying multiple separate adapters.
This USB 3.0 hub is perfect for travel, such as back-and-forth trips from home to office. Plus, the compact hub takes up minimal space on a desk, so you can use it in hot-desk or BYOD (Bring Your Own Device) environments.
This bus-powered USB hub installs quickly and easily, and it's natively supported in Windows 10 and 8.1, as well as Mac OS 10.11 and 10.10, with no additional drivers or software required. You can also avoid the nuisance and cost of purchasing new devices by using the USB 3.0 hub plus GbE with your current USB 2.0 and 1.x devices.
  • Looks great while expanding your connectivity
    This high-quality, Apple style USB hub features a Gigabit Ethernet port, giving you an easy way to expand your MacBook connectivity. And because the hub integrates a Gigabit Ethernet port, you can add wired network connectivity to your laptop in a location where Wi-Fi is unreliable or unavailable. The hub's built-in USB cable has sufficient length to reach your laptop's USB 3.2 Gen 1 port, regardless of where the port is located. Plus, the stylish hub features three USB 3.2 Gen 1 (also known as USB 3.2 Gen 1) ports in a compact housing. And, its silver, sandblasted finish provides a unique and trendy look when compared to traditional hubs.
  • Portable and rugged
    The hub features a rugged yet lightweight housing, so there's no need to sacrifice dependability for portability. With its compact, USB-powered design and a built-in USB cable, you can tuck the combination hub neatly into your travel bag, and avoid the nuisance of carrying multiple separate adapters. This USB 3.2 Gen 1 hub is perfect for travel, such as back-and-forth trips from home to office. Plus, the compact hub takes up minimal space on a desk, so you can use it in hot-desk or BYOD (Bring Your Own Device) environments.
  • Save money and time
    This bus-powered USB hub installs quickly and easily, and it's natively supported in Windows , Mac, and Chrome OS , with no additional drivers or software required. You can also avoid the nuisance and cost of purchasing new devices by using the USB 3.2 Gen 1 hub plus GbE with your current USB 2.0 and 1.x devices. The ST3300G3UA is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com 3-Port USB 3.0 Hub with Gigabit Ethernet - Up to 5Gbps - Portable USB Port Expander with Built-in Cable (ST3300G3UA) - hub - 3 ports
Hub - 3 ports
Subtype
USB
Ports
3 x SuperSpeed USB 3.0 + 1 x 10/100/1000
Jumbo Frame Support
Auto-negotiation, auto-uplink (auto MDI/MDI-X), full duplex mode
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, USB 1.1, USB 2.0, USB 3.0, IEEE 802.3az
11.1 cm x 3.5 cm x 2 cm
40 g
White, silver
Microsoft Windows Server 2008 R2, Google Chrome OS, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.7 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Hub - 3 ports
Subtype
USB
Ports
Jumbo Frame Support
Status Indicators
Power, link/activity
3 x USB 3.0 Type A , 1 x Gigabit LAN RJ-45
White, silver
1 x USB power cable
Plug and Play, FCC, RoHS, WEEE
11.1 cm
3.5 cm
2 cm
40 g
10 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
BST8 StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.73
BST8 StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - White In Stock £37.08
BST8 StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable In Stock £38.80
BST8 StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £8.90
BST8 StarTech.com USB 3.0 Network Adapter-Silver In Stock £23.53
BST8 StarTech.com 3Pt Portable USB 3.0 Hub + GbE In Stock £33.70
BST8 StarTech.com 7 Port Compact USB 3.0 Hub In Stock £43.64
BST8 StarTech.com 4 Port Portable USB 3.0 Hub In Stock £23.79
BST8 StarTech.com USB-C to GbE Adapter - Silver In Stock £26.54
BST8 StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop In Stock £42.51
BST8 StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White In Stock £25.61
BST8 StarTech.com 3PT USB 3.0 C Hub + GbE PD 2.0 In Stock £45.82
Type: USB Hub
Speed: [N/A]
Ports: 3
