StarTech.com 3m USB C to DisplayPort Cable - Black
Quicklinx: D9KLWS00 Mfr#: CDP2DPMM3MB
Length: 3m
Colours:
22 In Stock
£26.32 ex VAT
£31.58 inc VAT
Use this USB-C to DP cable to connect your USB Type C computer directly to a monitor, without additional adapters. This USB-C to DisplayPort adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your DP monitor or projector. The adapter offers a connection distance of up to 3 m (10 ft.) and works with USB-C devices that support DP Alt Mode, such as the MacBook, Chromebook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 3 m (10 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation.
For shorter installations, StarTech.com also offers a 1 m (3 ft.) USB-C to DisplayPort cable (CDP2DPMM1MB) and 1.8 m (6 ft.) USB-C to DisplayPort cable (CDP2DPMM6B), enabling you to choose the right cable length for your custom installation needs.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K 60Hz monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display.
Plus, the adapter is still compatible with lower display resolutions, such as 1080p, which makes it a great accessory for your current home, office or other HD work environment, while future-proofing for 4K 60Hz implementation.
  • High resolution capabilities
    The cable supports a maximum external resolution of 3840 x 2160, providing clarity for 4K displays.
  • Versatile compatibility
    Compatible with USB-C devices and Thunderbolt 3, allowing for usage across various systems and setups.
  • Compliance with standards
    Meets compliance standards including FCC, RoHS, and WEEE, ensuring environmental responsibility.
  • Operating temperature range
    Designed to function smoothly between 0°C and 40°C, this cable is suitable for diverse environments.
  • Advanced audio support
    Supports 7.1 channel surround sound, making it suitable for immersive audio experiences.
StarTech.com 9.8ft/3m USB C to DisplayPort 1.2 Cable 4K 60Hz, USB-C to DisplayPort Adapter Cable HBR2, USB Type-C DP Alt Mode to DP Monitor Video Cable, Compatible w/ Thunderbolt 3, Black - USB-C Male to DP Male (CDP2DPMM3MB) - external video adapter - STM32F072CBU6 - black
External video adapter
Bus Type
USB-C
Graphics Engine
STM32F072CBU6
Max Resolution
3840 x 2160
Interfaces Details
DisplayPort (male connector)
2 cm 1 cm
Length
3 m
Enclosure Colour
3-year warranty
Bus Type
USB-C
Graphics Engine
STM32F072CBU6
Max Resolution
3840 x 2160 at 60 Hz
Interfaces Details
HD/4k Ready, Thunderbolt 3 compatible, 7.1 channel surround sound ready
FCC, RoHS, WEEE
2 cm
1 cm
Length
3 m
180 g
Enclosure Colour
Limited warranty - 3 years
20 - 70%
D9KL StarTech.com 2m USB-C to HDMI Cable In Stock £27.94
D9KL StarTech.com 1m USB-C to HDMI Cable In Stock £25.27
D9KL StarTech.com 1m USB-C to VGA Cable In Stock £19.38
D9KL StarTech.com 2m USB-C to VGA Cable In Stock £22.00
D9KL StarTech.com 3m USB C to DisplayPort Cable - White In Stock £20.18
D9KL StarTech.com 3m USB C to DisplayPort Cable - Black In Stock £26.32
Length: 3m
