Eliminate clutter by connecting your USB Type-C computer directly to an HDMI display, without additional adapters. This USB-C to HDMI adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your HDMI monitor, television or projector. The adapter supports a connection distance of up to 1 m (3 ft.) and works with USB-C devices that support DP alt mode, such as the MacBook, ChromeBook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 1 m (3 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. For longer installations, a 2 m (6 ft.) USB-C to HDMI cable enabl you to choose the right cable length for your custom installation needs.
The adapter cable is easy to connect, through the versatility and convenience of the USB Type-C port on your device. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always connect. This saves you the frustration of trying to insert it correctly when you're docking your computer to your workstation or office hot desk.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection to deliver the astonishing quality of Ultra HD to your 4K display.
The adapter is backward compatible with 1080p displays, ensuring the adapter will also work for HD applications at your home or office.
Your USB-C equipped device must support video (DP alt mode) to work with this adapter.
Clutter-free installation
At 1 m (3 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. -
Hassle-free connection with USB Type-C
The adapter cable is easy to connect, through the versatility and convenience of the USB Type-C port on your device. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always connect. This saves you the frustration of trying to insert it correctly when you're docking your computer to your workstation or office hot desk. -
Astonishing picture quality
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection to deliver the astonishing quality of Ultra HD to your 4K display. The adapter is backward compatible with 1080p displays, ensuring the adapter will also work for HD applications at your home or office.
- StarTech USB C to HDMI Cable - 3 ft / 1m - USB-C to HDMI 4K 30Hz - USB Type C to HDMI - Computer Monitor Cable (CDP2HDMM1MB) - external video adapter
- External video adapter
- Bus Type
- USB-C
- Max Resolution
- 3840 x 2160
- Interfaces Details
- HDMI (male connector)
- Cable Length
- 1 m
- 3-year warranty
- Designed For
- P/N: TB33A1C
- Bus Type
- USB-C
- Max Resolution
- 3840 x 2160
- FCC, RoHS, WEEE
- Cable Length
- 1 m
- Limited warranty - 3 years
- 0 °C
- 45 °C
- 5 - 95% (non-condensing)
- Designed For
- P/N: TB33A1C
StarTech.com USB-C to HDMI Adapter | In Stock | £15.52 |
StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz | In Stock | £7.64 |
StarTech.com 6ft USB-C to DisplayPort Cable | In Stock | £18.72 |
StarTech.com 2m USB-C to DVI Cable | In Stock | £23.46 |
StarTech.com 2m USB-C to HDMI Cable | In Stock | £27.94 |
StarTech.com 1m USB-C to DVI Cable | In Stock | £11.22 |
StarTech.com 1m USB-C to HDMI Cable | In Stock | £25.27 |
StarTech.com 1m USB-C to VGA Cable | In Stock | £19.38 |
StarTech.com 2m USB-C to VGA Cable | In Stock | £21.96 |
StarTech.com USB-C to HDMI - Power Delivery | In Stock | £23.48 |
StarTech.com 6 ft USB C to DP Cable - White | In Stock | £9.11 |
StarTech.com 3m USB C to DisplayPort Cable - White | In Stock | £20.18 |
StarTech.com 3m USB C to DisplayPort Cable - Black | In Stock | £26.32 |
StarTech.com 1.8m 6 ft USB C to mDP Cable | In Stock | £9.71 |
StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m | In Stock | £20.26 |
StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable | In Stock | £18.04 |
StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K | In Stock | £23.05 |
StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? | In Stock | £19.80 |
StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable | In Stock | £11.44 |
StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable | In Stock | £16.89 |
StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable | In Stock | £16.75 |
StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz | In Stock | £28.47 |
StarTech.com 6.6ft USB C to DP 1.2 Cable | In Stock | £31.29 |
