Quicklinx: D0ZRWS00 Mfr#: USB2CC3M
Length: 3m
Hurry, only 1 left in stock!
£13.00 ex VAT
£15.60 inc VAT
Charge and sync your USB Type-C mobile devices, over longer distances. This USB-C to USB-C cable makes it easy to charge and sync USB Type-C devices, such as the Samsung Galaxy S8, S8+, Nexus 6P, and 5X phones, using the USB-C port on your computer.
The cable is also compatible with Thunderbolt 3 ports, which means you can charge and sync your USB-C mobile devices using your Thunderbolt 3 laptop.
The 3-meter cable gives you the extra length you need to overcome distance restrictions and stay connected. You can charge and sync your USB-C mobile device, in almost any environment. Even while you're taking notes in a boardroom, catching up on emails in your hotel room, or reading in a coffee shop, your mobile device will reach your computer or wall charger more comfortably.
With up to 3A of power output, you can use this USB Type-C cable to power a USB-C laptop, such as your Apple MacBook or Chromebook Pixel. Simply connect the cable to your USB-C laptop and to a USB-C wall charger.
Replace the USB-C cable that came with your device, or keep one as a spare while you're traveling, so that all of your devices will be ready to use whenever you need them while you're on the road.
  • Charge and sync your mobile devices over longer distances
  • Power your laptop
    With up to 3A of power output, you can use this USB Type-C cable to power a USB-C laptop, such as your Apple MacBook or Chromebook Pixel . Simply connect the cable to your USB-C laptop and to a USB-C wall charger.
  • Keep the cable as a spare while you're traveling
    Replace the USB-C cable that came with your device, or keep one as a spare while you're traveling, so that all of your devices will be ready to use whenever you need them while you're on the road. The USB2CC3M from StarTech.com is backed by a lifetime warranty for guaranteed reliability.
StarTech.com USB C to USB C Cable - 3m / 10 ft - USB Cable Male to Male - USB-C Cable - USB-C Charge Cable - USB Type C Cable - USB 2.0 (USB2CC3M) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 3 m
USB-C cable
Shielded
Length
3 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Thunderbolt 3 / USB 2.0
P/N: DKT30CHD
USB-C cable
Shielded
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
23/28
Plated Connector
Nickel
Length
3 m
100 g
Connector
24 pin USB-C - male
24 pin USB-C - male
Thunderbolt 3 / USB 2.0, RoHS, WEEE
P/N: DKT30CHD
D0ZR StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 In Stock £9.47
D0ZR StarTech.com 2m 6ft USB 2.0 USB-C Cable In Stock £11.21
D0ZR StarTech.com 0.5m USB 2.0 USB C Cable In Stock £9.20
D0ZR StarTech.com 1m Right Angle USB C Cable In Stock £11.21
D0ZR StarTech.com 3m USB 2.0 Type C Cable In Stock £13.00
Length: 3m
