Charge your USB 2.0 USB-C devices, over longer distances. This USB-C to USB-C cable makes it easy to charge and sync USB Type-C devices, such as the Nokia N1 tablet and Nexus 6P and 5X phones, using the USB-C port on your computer.
The cable is also compatible with Thunderbolt 3 ports, which means you can charge and sync your USB-C mobile devices using your Thunderbolt 3 laptop.
The 2-meter cable gives you the extra length you need to overcome distance restrictions and stay connected. You can charge and sync your USB-C mobile device, in almost any environment. Even while you're taking notes in a boardroom, catching up on emails in your hotel room, or reading in a coffee shop, your mobile device will reach your computer or wall charger more comfortably.
With up to 3A of power output, you can use this USB Type-C cable to power a USB-C laptop, such as your Apple MacBook or Chromebook Pixel . Simply connect the cable to your USB-C laptop and to a USB-C wall charger.
Replace the USB-C cable that came with your device, or keep one as a spare while you're traveling, so that all of your devices will be ready to use whenever you need them while you're on the road.
The cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, ensuring a reliable, high-quality cable for all of your USB-C devices.
- StarTech.com 2m 6 ft USB C Cable - M/M - USB 2.0 - USB-IF Certified - USB-C Charging Cable - USB 2.0 Type C Cable (USB2CC2M) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
- USB-C cable
- Technology
- Double shielded
- Length
- 2 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Thunderbolt 3 / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: DKT30CHD, HB30C1A1CPD, HB30C3A1CFBW
- USB-C cable
- Technology
- Double shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 22/30
- Plated Connector
- Nickel
- Length
- 2 m
- Black
- 42 g
- Connector
- Thunderbolt 3 / USB 2.0, RoHS
- Designed For
