StarTech.com 3m USB 2.0 C to B Cable
Quicklinx: CY2TWS00 Mfr#: USB2CB3M
Length: 3m
47 In Stock
£16.56 ex VAT
£19.87 inc VAT
Connect USB 2.0 USB-B devices to your USB-C or Thunderbolt 3 computer. This USB-C to USB-B printer cable lets you connect your USB 2.0 peripheral devices, such as a printer, external drive or scanner to your USB Type-C laptop or tablet. The cable is also compatible with Thunderbolt 3 ports.
The longer cable lets you organize your desk to match your needs, enabling to connect your device up to 3 meters away from your computer.
  • Durable construction
    The cable features a robust PVC jacket, providing protection against wear and tear to ensure long-lasting usage.
  • High compatibility
    This cable supports Thunderbolt 3 and USB 2.0 standards, making it suitable for a range of devices including printers, laptops, and more.
  • Optimized performance
    With nickel-plated connectors, users can expect enhanced conductivity and a reliable connection for all printing needs.
  • Sufficient length
    At 10 ft / 3 m, this cable offers ample length to connect devices situated at a distance, reducing the need for additional extensions.
  • Easy installation
    Both connectors are designed straight for easy Plug-and-Play functionality, making setup hassle-free.
StarTech.com USB C to USB B Printer Cable - 10 ft / 3m - USB C Printer Cable - USB C to USB B Cable - USB Type C to Type B (USB2CB3M) - USB-C cable - 24 pin USB-C to USB Type B - 3 m
USB-C cable
Length
3 m
Connector
24 pin USB-C - male - straight
Connector (Second End)
4 pin USB Type B - male - straight
Thunderbolt 3 / USB 2.0
P/N: SV231DHU34K6, SV231HU34K6, SV231QDPU34K, SV431HU34K6
USB-C cable
Jacket Material
PVC
American Wire Gauge (AWG)
22/28
Plated Connector
Nickel
Length
3 m
68 g
Connector
Thunderbolt 3 / USB 2.0, RoHS
CY2T StarTech.com 1m USB 2.0 USB-C to USB-B Cable In Stock £10.13
CY2T StarTech.com 2m 6ft USB 2.0 C to B Cable In Stock £13.69
CY2T StarTech.com 2m 6ft USB 3.0 C to B Cable In Stock £14.66
CY2T StarTech.com 3m USB 2.0 C to B Cable In Stock £16.56
CY2T StarTech.com 0.5m USB 2.0 C to B Cable In Stock £8.87
Length: 3m
