StarTech.com 2m 6ft USB 2.0 C to B Cable
Quicklinx: CTWGWS00 Mfr#: USB2CB2M
Length: 2m
23 In Stock
£15.37 ex VAT
£18.44 inc VAT
Connect USB 2.0 USB-B devices to your USB-C or Thunderbolt 3 computer. This USB-C to USB-B cable lets you connect your USB 2.0 peripheral devices, such as a printer, external drive or scanner to your USB Type-C laptop or tablet. The cable is also compatible with Thunderbolt 3 ports.
  • Reliable Connectivity
    The 24 pin USB-C connector on one end ensures secure connectivity with modern devices, while the 4 pin USB Type-B connector is designed for compatibility with a wide range of printers and peripherals.
  • Enhanced Durability
    Made with aluminum mylar foil and braid shielding, this cable resists wear and interference, providing a stable connection for data transfer and device communication.
  • Optimal Performance
    With an American Wire Gauge of 22/30, this cable supports high-speed transmission rates, making it suitable for quick data exchanges and efficient printing tasks.
  • Versatile Applications
    This cable is ideal for connecting USB Type-C devices to USB Type-B equipment, allowing for seamless integration across various devices in professional and home environments.
  • Environmentally Compliant
    The cable adheres to RoHS and WEEE standards, ensuring it is manufactured with respect for the environment, aligning with modern eco-friendly practices.
StarTech.com 2m 6ft USB C to USB B Cable - USB 2.0 - USB Type C Printer Cable M/M - USB 2.0 Type-C to Type-B Cable (USB2CB2M) - USB-C cable - 24 pin USB-C to USB Type B - 2 m
USB-C cable
Shielded
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
4 pin USB Type B - male
Thunderbolt 3 / USB 2.0
USB-C cable
Shielded
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
22/30
Plated Connector
Nickel
Length
2 m
63 g
Connector
24 pin USB-C - male
Thunderbolt 3 / USB 2.0, RoHS, WEEE
CTWG StarTech.com 1m USB 2.0 USB-C to USB-B Cable In Stock £9.97
CTWG StarTech.com 2m 6ft USB 2.0 C to B Cable In Stock £15.37
CTWG StarTech.com 2m 6ft USB 3.0 C to B Cable In Stock £13.23
CTWG StarTech.com 3m USB 2.0 C to B Cable In Stock £16.10
CTWG StarTech.com 0.5m USB 2.0 C to B Cable In Stock £8.73
Length: 2m
