StarTech.com 3m USB 2.0 C to B Cable
Quicklinx: CY2TWS00 Mfr#: USB2CB3M
13 In Stock
£19.57 ex VAT
£23.48 inc VAT
Connect USB 2.0 USB-B devices to your USB-C or Thunderbolt 3 computer. This USB-C to USB-B printer cable lets you connect your USB 2.0 peripheral devices, such as a printer, external drive or scanner to your USB Type-C laptop or tablet. The cable is also compatible with Thunderbolt 3 ports.
The longer cable lets you organize your desk to match your needs, enabling to connect your device up to 3 meters away from your computer.
StarTech.com USB C to USB B Printer Cable - 10 ft / 3m - USB C Printer Cable - USB C to USB B Cable - USB Type C to Type B (USB2CB3M) - USB-C cable - 24 pin USB-C to USB Type B - 3 m
USB-C cable
Length
3 m
Connector
24 pin USB-C - male - straight
Connector (Second End)
4 pin USB Type B - male - straight
Thunderbolt 3 / USB 2.0
P/N: SV231DHU34K6, SV231HU34K6, SV231QDPU34K, SV431HU34K6
USB-C cable
Jacket Material
PVC
American Wire Gauge (AWG)
22/28
Plated Connector
Nickel
Length
3 m
68 g
Connector
Thunderbolt 3 / USB 2.0, RoHS
