StarTech.com 3m USB 2.0 A to Left Angle B Cable - M/M
Quicklinx: 95R8WS00 Mfr#: USBAB3ML
Length: 3m
30 In Stock
£5.25 ex VAT
£6.30 inc VAT
Connect hard-to-reach USB 2.0 peripherals, for installation in narrow spaces. The USBAB3ML 3-meter USB printer cable features one USB-A male connector and one left-angle USB-B male connector, providing a high-quality connection to USB 2.0 peripherals and enabling installation in narrow spaces.
As an alternative, StarTech.com also offers a 3m USB 2.0 A to Right Angle B Cable (USBAB3MR), which provides the same convenience as this left-angled cable, but allows you to connect to your USB device from the opposite direction.
  • Versatile cable design
    The cable features a left angle USB B connector, allowing for flexibility in tight spaces. This design helps in reducing stress on the connection port, making it suitable for various setups.
  • Robust construction
    Constructed with nickel-plated connectors, this cable ensures reliable performance and durability. The robust materials used resist damage from frequent plugging and unplugging.
  • Compliant with USB 2.0 standards
    This cable supports USB 2.0 technology, providing efficient data transfer rates suitable for printers and other USB devices.
  • Optimized for signal integrity
    The shielded design of the cable minimizes interference, ensuring high-quality signal transfer and reducing the risk of data loss.
  • Convenient 3m length
    With a length of 3m, this cable allows for extensive reach, perfect for connecting devices across larger distances without compromising performance.
StarTech.com 3m USB 2.0 A to Left Angle B Cable Cord - 3 m USB Printer Cable - Left Angle USB B Cable - 1x USB A (M), 1x USB B (M) (USBAB3ML) - USB cable - USB Type B to USB - 3 m
USB cable
Shielded
Left-angled connector
Length
3 m
Connector
4 pin USB Type B - male
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
P/N: ICUSB232D
USB cable
Shielded
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
Length
3 m
Connector
USB / USB 2.0, RoHS
P/N: ICUSB232D
95R8 StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M In Stock £20.17
95R8 StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M In Stock £33.33
95R8 StarTech.com 1m USB 2.0 A to Right Angle B Cable - M/M In Stock £5.20
95R8 StarTech.com 3M RIGHT ANGLE USB PRINTER In Stock £5.82
95R8 StarTech.com 2m USB 2.0 A to Right Angle B Cable - M/M In Stock £5.20
95R8 StarTech.com 2m USB 2.0 A to Left Angle B Cable - M/M In Stock £5.25
95R8 StarTech.com 1m USB 2.0 A to Left Angle B Cable - M/M In Stock £5.00
95R8 StarTech.com 3m USB 2.0 A to Left Angle B Cable - M/M In Stock £5.25
Length: 3m
