Connect hard-to-reach USB 2.0 peripherals, for installation in narrow spaces. The USBAB1ML 1-meter USB printer cable features one USB-A male connector and one left-angle USB-B male connector, providing a high-quality connection to USB 2.0 peripherals and enabling installation in narrow spaces.
As an alternative, StarTech.com also offers a 1m USB 2.0 A to Right Angle B Cable (USBAB1MR), which provides the same convenience as this left-angled cable, but allows you to connect to your USB device from the opposite direction.
Convenient left angle connector
The left angle connector allows for optimal placement of devices, making it easier to connect in tight areas without the risk of damaging the ports. -
Stable data transmission
With its shielded design, this cable ensures stable and reliable data transfer, minimizing the potential for signal loss and interference. -
Durable construction
Nickel-plated connectors provide enhanced durability, ensuring that the cable can withstand regular use while maintaining performance quality. -
Compliant with industry standards
This cable meets USB 2.0 standards, ensuring compatibility with a wide range of devices and enabling efficient data transfer.
- StarTech.com 1m USB 2.0 A to Left Angle B Cable Cord - 1 m USB Printer Cable - Left Angle USB B Cable - 1x USB A (M), 1x USB B (M) (USBAB1ML) - USB cable - USB Type B to USB - 1 m
- USB cable
- Technology
- Shielded
- Left-angled connector
- Length
- 1 m
- Connector
- 4 pin USB Type B - male
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 24/28
- Plated Connector
- Nickel
- Length
- 1 m
- Black
- Connector
- USB / USB 2.0, RoHS
StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M | In Stock | £20.24 |
StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M | In Stock | £32.53 |
StarTech.com 1m USB 2.0 A to Right Angle B Cable - M/M | In Stock | £5.19 |
StarTech.com 3M RIGHT ANGLE USB PRINTER | In Stock | £4.73 |
StarTech.com 2m USB 2.0 A to Right Angle B Cable - M/M | In Stock | £5.10 |
StarTech.com 2m USB 2.0 A to Left Angle B Cable - M/M | In Stock | £5.42 |
StarTech.com 1m USB 2.0 A to Left Angle B Cable - M/M | In Stock | £4.89 |
StarTech.com 3m USB 2.0 A to Left Angle B Cable - M/M | In Stock | £4.79 |
