StarTech.com 2m USB 2.0 A to Left Angle B Cable - M/M
Quicklinx: 95DWWS00 Mfr#: USBAB2ML
Length: 2m
10 In Stock
£5.26 ex VAT
£6.31 inc VAT
Connect hard-to-reach USB 2.0 peripherals, for installation in narrow spaces. The USBAB2ML 2-meter USB printer cable features one USB-A male connector and one left-angle USB-B male connector, providing a high-quality connection to USB 2.0 peripherals and enabling installation in narrow spaces.
As an alternative, StarTech.com also offers a 2m USB 2.0 A to Right Angle B Cable (USBAB2MR), which provides the same convenience as this left-angled cable, but allows you to connect to your USB device from the opposite direction.
  • Versatile connector design
    The left angle connector of this USB cable allows for easy connections in tight spaces, making it suitable for various setups and environments.
  • Reliable data transfer capacity
    Designed to comply with USB 2.0 standards, this cable ensures efficient data transfer rates, supporting a range of devices with ease.
  • Durable and efficient construction
    Built with a shielded design and nickel-plated connectors, this cable promotes durability and reduces interference for consistent connectivity.
  • Flexibility and compatibility
    With a 24/28 American Wire Gauge, this cable offers the flexibility needed for a variety of applications while maintaining compatibility with numerous devices.
StarTech.com 2m USB 2.0 A to Left Angle B Cable Cord - 2 m USB Printer Cable - Left Angle USB B Cable - 1x USB A (M), 1x USB B (M) (USBAB2ML) - USB cable - USB Type B to USB - 2 m
USB cable
Shielded
Left-angled connector
Length
2 m
Connector
4 pin USB Type B - male
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
USB cable
Shielded
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
Length
2 m
Connector
USB / USB 2.0, RoHS
95DW StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M In Stock £20.17
95DW StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M In Stock £33.33
95DW StarTech.com 1m USB 2.0 A to Right Angle B Cable - M/M In Stock £5.59
95DW StarTech.com 3M RIGHT ANGLE USB PRINTER In Stock £5.82
95DW StarTech.com 2m USB 2.0 A to Right Angle B Cable - M/M In Stock £5.20
95DW StarTech.com 2m USB 2.0 A to Left Angle B Cable - M/M In Stock £5.26
95DW StarTech.com 1m USB 2.0 A to Left Angle B Cable - M/M In Stock £5.00
95DW StarTech.com 3m USB 2.0 A to Left Angle B Cable - M/M In Stock £5.43
Length: 2m
