StarTech.com 3M RIGHT ANGLE USB PRINTER
Quicklinx: 93FFWS00 Mfr#: USBAB3MR
Length: 3m
£6.01 ex VAT
£7.21 inc VAT
Connect hard to reach USB 2.0 peripherals, for installation in narrow spaces. The USBAB3MR 3-meter USB printer cable features one USB 'A' male connector and one right-angle USB 'B' male connector, providing a high-quality connection to USB 2.0 peripherals.
The right-angled USB 'B' connector allows you to connect to your hard-to-reach USB 2.0 printers, scanners, external hard drives, etc. and enables installation in narrow spaces.
  • Enhanced durability
    The 3 m USB 2.0 A to Right Angle B Cable Cord features a nickel-plated connector that ensures a reliable connection and enhances durability, making it a dependable choice for daily use.
  • Optimized connectivity
    With an American Wire Gauge (AWG) of 24/28, this USB printer cable provides optimal electrical conductivity and signal clarity, ensuring high-performance connectivity between devices.
  • Flexible compatibility
    Designed to meet the USB 2.0 standard, this right angle USB B cable is compatible with a wide range of devices, including PCs, making it a versatile addition to any tech setup.
StarTech.com 3m USB 2.0 A to Right Angle B Cable Cord - 3 m USB Printer Cable - Right Angle USB B Cable - 1x USB A (M), 1x USB B (M) (USBAB3MR) - USB cable - USB Type B to USB - 3 m
USB cable
90° connector
Length
3 m
Connector
4 pin USB Type B - male
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
USB cable
24/28
Plated Connector
Nickel
90° connector
Length
3 m
Connector
USB / USB 2.0, RoHS
93FF StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M In Stock £21.10
93FF StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M In Stock £33.91
93FF StarTech.com 1m USB 2.0 A to Right Angle B Cable - M/M In Stock £5.19
93FF StarTech.com 3M RIGHT ANGLE USB PRINTER In Stock £6.01
93FF StarTech.com 2m USB 2.0 A to Right Angle B Cable - M/M In Stock £5.10
Length: 3m
