Connect hard-to-reach USB 2.0 peripherals, for installation in narrow spaces. The USBAB1MR 1-meter USB printer cable features one USB 'A' male connector and one right-angle USB 'B' male connector, providing a high-quality connection to USB 2.0 peripherals.
The right-angled USB 'B' connector allows you to connect to your hard-to-reach USB 2.0 printers, scanners, external hard drives, etc. and enables installation in narrow spaces.
Enhanced durability
Featuring a nickel-plated connector, this USB 2.0 A to Right Angle B Cable ensures a reliable connection with enhanced durability, suitable for frequent plugging and unplugging. -
Optimized connectivity
With an American Wire Gauge (AWG) of 24/28, this cable ensures efficient data transmission and power supply, making it ideal for connecting devices such as printers and scanners to your PC. -
Flexible design
The right-angle USB B connector offers a flexible solution for tight spaces, reducing strain on the cable and preventing damage to the port, ensuring a longer lifespan for your devices.
- StarTech.com 1m USB 2.0 A to Right Angle B Cable Cord - 1 m USB Printer Cable - Right Angle USB B Cable - 1x USB A (M), 1x USB B (M) (USBAB1MR) - USB cable - USB Type B to USB - 1 m
- USB cable
- 90° connector
- Length
- 1 m
- Connector
- 4 pin USB Type B - male
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- American Wire Gauge (AWG)
- 24/28
- Plated Connector
- Nickel
- 90° connector
- Length
- 1 m
- Black
- Connector
- USB / USB 2.0, RoHS
StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M | In Stock | £21.10 |
StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M | In Stock | £33.91 |
StarTech.com 1m USB 2.0 A to Right Angle B Cable - M/M | In Stock | £5.19 |
StarTech.com 3M RIGHT ANGLE USB PRINTER | In Stock | £6.01 |
StarTech.com 2m USB 2.0 A to Right Angle B Cable - M/M | In Stock | £5.10 |
