Connect hard to reach USB 2.0 peripherals, for installation in narrow spaces. The USBAB3MR 3-meter USB printer cable features one USB 'A' male connector and one right-angle USB 'B' male connector, providing a high-quality connection to USB 2.0 peripherals.
The right-angled USB 'B' connector allows you to connect to your hard-to-reach USB 2.0 printers, scanners, external hard drives, etc. and enables installation in narrow spaces.
- StarTech.com 3m USB 2.0 A to Right Angle B Cable - M/M - USB cable - 3 m
- USB cable
- 90° connector
- Length
- 3 m
- Connector
- 4 pin USB Type B - male
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- American Wire Gauge (AWG)
- 24/28
- Plated Connector
- Nickel
- 90° connector
- Length
- 3 m
- Black
- Connector
- USB / USB 2.0, RoHS
