StarTech.com 3m Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable
Quicklinx: 9F5XWS00 Mfr#: N6PATC3MRD
Length: 3m
Colour: Red
Hurry, only 1 left in stock!
£8.80 ex VAT
£10.56 inc VAT
Express delivery Order within the next hour for delivery tomorrow
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC3MRD Cat 6 Patch Cable (3m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable red PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
  • Reliable performance
    This cable supports a tested frequency of up to 500 MHz, providing reliable speed and performance suitable for fast Internet and network connections.
  • Durable construction
    Constructed with a PVC jacket that enhances durability, ensuring the cable withstands regular use without compromising performance.
  • User-friendly design
    The snagless design prevents damage during installation, making it easy to connect devices without worrying about tangling or damage.
  • Versatile connectivity
    Equipped with RJ-45 male connectors on both ends, the cable easily connects to various network devices, providing a practical choice for multiple environments.
  • Safety compliance
    This cable meets RoHS and ETL compliance standards, ensuring a product that is safe and environmentally friendly.
StarTech.com 3m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Red, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC3MRD) - patch cable - 3 m - red
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Molded, snagless
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Red
Network Cable Type
Patch cable - CAT 6
Jacket Material
PVC
American Wire Gauge (AWG)
24
Pairs per Cable
4 pairs
Plated Connector
Gold
Molded, snagless
Length
3 m
Red
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL - up to 500 MHz
9F5X StarTech.com 3m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £8.22
9F5X StarTech.com 3m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £5.42
9F5X StarTech.com 3m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £5.47
9F5X StarTech.com 3m Orange Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £6.15
9F5X StarTech.com 3m Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £8.80
9F5X StarTech.com 3m White Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £6.07
9F5X StarTech.com 3m Yellow Cat6 Patch Cable In Stock £5.58
9F5X StarTech.com 3m Green Cat6 Patch Cable In Stock £5.29
9F5X StarTech.com 3m Purple Cat6 Patch Cable In Stock £5.35
Length: 3m
Colour: Red
