StarTech.com 3m Yellow Cat6 Patch Cable
Quicklinx: B27GWS00 Mfr#: N6PATC3MYL
16 In Stock
£6.15 ex VAT
£7.38 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC3MYL Cat 6 patch cable (3m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable yellow PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
  • Reliable performance
    The cable supports a tested frequency of up to 500 MHz, providing stable and high-speed data transmission suitable for various networking tasks.
  • Enhanced durability
    Constructed with a PVC jacket and gold-plated connectors, this cable is designed to withstand wear while maintaining excellent performance.
  • Easy connectivity
    The snagless design allows for quick connections, minimizing the risk of damage to adjacent ports during installation.
  • Versatile compatibility
    Equipped with male RJ-45 connectors on both ends, this patch cable is compatible with a wide array of devices, making it an ideal choice for home and office use.
  • Industry compliant
    This cable meets RoHS, ETL, and TIA/EIA-568-B standards, ensuring it adheres to necessary regulations for safe and effective use.
StarTech.com 3m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Yellow, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC3MYL) - patch cable - 3 m - yellow
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wires per Cable
4 wires
Snagless
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Yellow
Network Cable Type
Patch cable - CAT 6
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
4 wires
Pairs per Cable
8 pairs
Plated Connector
Gold
Snagless
Length
3 m
Yellow
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
