StarTech.com 3m LC/LC OM5 Fiber Cable
Quicklinx: HHX8WS00 Mfr#: LCLCL-3M-OM5-FIBER
Length: 3m
Colour: Green
16 In Stock
£24.53 ex VAT
£29.43 inc VAT
OM5 FIBER CABLE: The OM5 LOMMF cable is optimized for 40/100 Gbps fiber optic networks. Extended 850-953 nm wavelength support enables SWDM (Short Wavelength Division Multiplexing) for greater channel isolation.
QUALITY CONSTRUCTION: LC/LC-UPC ends for better return loss than PC polishing - Color-coded connectors for polarity - Fiber core insensitive to bending, Aramid sheathing for a maggione bend radius.
RELIABLE: individually tested for guaranteed performance (testing included). LSZH sheathing emits low toxic fumes in case of combustion. Safe in poorly ventilated spaces. Attenuation value <2.4 dB/km meets/exceeds standards.
WIDE COMPATIBILITY: OM5 multimode cable supports 10/40/100G networks, compatible with OM4/OM3. High resistance to microbending facilitates bending in complex installations, ideal for fiber switches/servers, SANs and SFP+/QSFP+/QSFP28 modules.
SPECIFICATIONS: OM5 - LC/LC (UPC) - 50/125µm - 850-953nm VCSEL/1300nm LED - Modal bandwidth: 4700MHz.km (850nm), 2470MHz.km (953nm) - Insertion loss: =0.3dB - Return loss: =30dB - Cable Ø: 2.9mm - Bend radius: 3-6cm
  • High-speed connectivity
    Experience fast data transfer rates of up to 100 Gbps, ideal for high-bandwidth applications and efficient data center operations.
  • Enhanced durability
    Featuring a Low Smoke Zero Halogen (LSZH) jacket, this cable minimizes the amount of toxic and corrosive gas emitted during combustion, ensuring a safer environment for all.
  • Optimized for laser
    Leveraging Laser-optimized multimode fiber (LOMMF) with a wavelength range of 840/953/1300 nm, this cable is engineered for superior performance in VCSEL-based networks.
  • Bend insensitive design
    Crafted to maintain signal integrity even when bent or twisted, this cable ensures consistent and reliable connectivity in tight spaces and challenging installations.
  • Eco-friendly choice
    Halogen-free construction not only enhances safety by reducing hazardous emissions but also underscores a commitment to environmental responsibility.
StarTech.com 3m (10ft) LC to LC (UPC) OM5 Multimode Fiber Optic Cable, 50/125µm Duplex LOMMF Zipcord, VCSEL, 40G/100G, Bend Insensitive, Low Insertion Loss, LSZH Fiber Patch Cord - patch cable - 3 m - green
Patch cable - OM5
Duplex fibre optic
Type of Fibre Optics
Multimode
Halogen-free, up to 100 Gbps data transfer rate, Laser-optimized multimode fibre (LOMMF), wavelength of 840/953/1300 nm
Length
3 m
Diameter
2.9 mm
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC/UPC multi-mode - male
Connector (Second End)
Green
Network Cable Type
Patch cable - OM5
Duplex fibre optic
Multimode
Jacket Material
50 / 125 micron
Length
3 m
Diameter
2.9 mm
Green
Connector
RoHS
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
0.81 cm
Shipping Weight
32.5 g
-20 °C
60 °C
HHX8 StarTech.com 10m LC/LC OM5 Fiber Cable In Stock £44.98
HHX8 StarTech.com 15m LC/LC OM5 Fiber Cable In Stock £56.38
HHX8 StarTech.com 1m LC/LC OM5 Fiber Cable In Stock £18.45
HHX8 StarTech.com 20m LC/LC OM5 Fiber Cable In Stock £69.18
HHX8 StarTech.com 2m LC/LC OM5 Fiber Cable In Stock £19.56
HHX8 StarTech.com 5m LC/LC OM5 Fiber Cable In Stock £30.22
HHX8 StarTech.com 7m LC/LC OM5 Fiber Cable In Stock £36.07
HHX8 StarTech.com 3m OM4 Multimode Fiber Cable In Stock £16.73
Length: 3m
Colour: Green
