StarTech.com 2m LC/LC OM5 Fiber Cable
Quicklinx: HHX7WS00 Mfr#: LCLCL-2M-OM5-FIBER
Length: 2m
Colour: Green
15 In Stock
£19.56 ex VAT
£23.47 inc VAT
OM5 FIBER CABLE: The OM5 LOMMF cable is optimized for 40/100 Gbps fiber optic networks. Extended 850-953 nm wavelength support enables SWDM (Short Wavelength Division Multiplexing) for greater channel isolation.
QUALITY CONSTRUCTION: LC/LC-UPC ends for better return loss than PC polishing - Color-coded connectors for polarity - Fiber core insensitive to bending, Aramid sheathing for a maggione bend radius.
RELIABLE: individually tested for guaranteed performance (testing included). LSZH sheathing emits low toxic fumes in case of combustion. Safe in poorly ventilated spaces. Attenuation value <2.4 dB/km meets/exceeds standards.
WIDE COMPATIBILITY: OM5 multimode cable supports 10/40/100G networks, compatible with OM4/OM3. High resistance to microbending facilitates bending in complex installations, ideal for fiber switches/servers, SANs and SFP+/QSFP+/QSFP28 modules.
SPECIFICATIONS: OM5 - LC/LC (UPC) - 50/125µm - 850-953nm VCSEL/1300nm LED - Modal bandwidth: 4700MHz.km (850nm), 2470MHz.km (953nm) - Insertion loss: =0.3dB - Return loss: =30dB - Cable Ø: 2.9mm - Bend radius: 3-6cm
  • High-speed connectivity
    Experience data transfer rates of up to 100 Gbps, ideal for high-bandwidth applications and efficient data center operations.
  • Enhanced durability
    Featuring a Low Smoke Zero Halogen (LSZH) jacket, this cable minimizes the amount of toxic and corrosive gas emitted during combustion, ensuring a safer environment for all.
  • Optimized for laser
    Laser-optimized multimode fiber (LOMMF) supports a wavelength of 840/953/1300 nm, making it perfect for use with VCSEL laser light sources and offering superior performance over traditional fiber cables.
StarTech.com 2m (6ft) LC to LC (UPC) OM5 Multimode Fiber Optic Cable, 50/125µm Duplex LOMMF Zipcord, VCSEL, 40G/100G, Bend Insensitive, Low Insertion Loss, LSZH Fiber Patch Cord - patch cable - 2 m - green
Patch cable - OM5
Duplex fibre optic
Type of Fibre Optics
Multimode
Halogen-free, up to 100 Gbps data transfer rate, Laser-optimized multimode fibre (LOMMF), wavelength of 840/953/1300 nm
Length
2 m
Diameter
2.9 mm
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC/UPC multi-mode - male
Connector (Second End)
Green
Network Cable Type
Patch cable - OM5
Duplex fibre optic
Multimode
Jacket Material
50 / 125 micron
Length
2 m
Diameter
2.9 mm
Green
Connector
RoHS
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
0.68 cm
Shipping Weight
23 g
-20 °C
60 °C
HHX7 StarTech.com 10m LC/LC OM5 Fiber Cable In Stock £44.98
HHX7 StarTech.com 15m LC/LC OM5 Fiber Cable In Stock £56.38
HHX7 StarTech.com 1m LC/LC OM5 Fiber Cable In Stock £17.78
HHX7 StarTech.com 20m LC/LC OM5 Fiber Cable In Stock £69.18
HHX7 StarTech.com 3m LC/LC OM5 Fiber Cable In Stock £24.53
HHX7 StarTech.com 5m LC/LC OM5 Fiber Cable In Stock £30.22
Length: 2m
Colour: Green
