StarTech.com 3m Green Cat 5e Patch Cable
Quicklinx: B2W3WS00 Mfr#: 45PAT3MGN
Length: 3m
Colour: Green
26 In Stock
£5.00 ex VAT
£6.00 inc VAT
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The 45PAT3MGN Cat5e patch cable (3m) meets or exceeds all Cat 5e cable specifications to ensure reliable Ethernet network connections, and features a durable green PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat5e patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Get the highest value for your cable investment with the Cat 5e cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
  • 100% copper for outstanding value
    Get the highest value for your cable investment with our Cat 5e cables, each one manufactured using high-quality copper conductors.
  • 24-gauge wire for high-performance network connection
  • 50-micron gold connectors provide peak conductivity
    Rely on our RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com 3m Green Cat5e / Cat 5 Snagless Patch Cable - patch cable - 3 m - green
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wires per Cable
8 wires
Molded, snagless, minimised Near-End Crosstalk (NEXT)
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Green
Network Cable Type
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
3 m
Green
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
B2W3 StarTech.com 3m Black Cat 5e Patch Cable In Stock £5.00
B2W3 StarTech.com 3m Green Cat 5e Patch Cable In Stock £5.00
B2W3 StarTech.com 3m Gray Cat 5e Patch Cable In Stock £5.00
B2W3 StarTech.com 3m Blue Cat 5e Patch Cable In Stock £5.09
B2W3 StarTech.com 3m Orange Cat 5e Patch Cable In Stock £5.11
B2W3 StarTech.com 3m Yellow Cat 5e Patch Cable In Stock £5.11
B2W3 StarTech.com 3m Red Cat 5e Patch Cable In Stock £5.00
B2W3 StarTech.com 3m White Cat 5e Patch Cable In Stock £5.09
Length: 3m
Colour: Green
