Connect 10GbE SFP+ network devices with this high-quality replacement SFP-H10GB-CU3M cable. The SFPCMM3M Cisco Compatible 3m SFP+ cable is a fully hot pluggable, direct attach cable, supporting 10 Gigabit Ethernet and Fiber Channel applications connected through (Small Form Factor Pluggable) SFP+ ports.
Designed for short length, high speed interconnects, this low power, low latency Twinax cable is a cost-effective alternative to fiber optic cable assemblies and is intended for short distance applications such as point-to-point in-rack and across rack network switch/server connections.
This 10GBASE-CU SFP+ Cable is compliant with MSA (Multi-Source Agreement) standards, making it a reliable replacement SFP-H10GB-CU3M cable.
Reliable design
The Cisco SFP-H10GB-CU3M compatible cable utilizes a 30 AWG twinaxial construction that ensures minimal signal degradation over its 3-meter length, making it suitable for high-speed data applications. -
Secure connections
Equipped with latching connectors, this cable provides a reliable connection to networking devices, minimizing the risk of accidental disconnections during operation. -
Environmental resilience
With a temperature range of 0 °C to 70 °C, this cable is designed to perform under varying environmental conditions, making it suitable for diverse installation scenarios. -
Quality standards compliance
This product meets RoHS and MSA compliance standards, ensuring it adheres to recognized safety and performance benchmarks within the industry.
 - StarTech.com Cisco SFP-H10GB-CU3M Compatible 3m 10G SFP+ to SFP+ Direct Attach Cable Twinax, 10GbE SFP+ Copper DAC 10 Gbps Low Power Passive Transceiver Module DAC, Cisco Firepower, ASR920 - Lifetime Warranty (SFPCMM3M) - direct attach cable - 3 m
 - Direct attach cable
- Technology
 - Twinaxial
 - Latching connectors
- Length
 - 3 m
- Connector
 - SFP+
- Connector (Second End)
 - SFP+
 - Limited lifetime warranty
- Designed For
 - P/N: ET10GSFP, PEX10000SFPI, PEX10GSFP, PEX10GSFP4I, PEX20000SFPI
- Network Cable Type
- Technology
 - Twinaxial
- Jacket Material
 - PVC
- American Wire Gauge (AWG)
 - 30
- Impedance
 - 100 Ohm
- Length
 - 3 m
- Connector
 - SFP+
 - SFP+
 - RoHS, MSA
 - 0 °C
 - 70 °C
- Designed For
                        StarTech.com 1m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable | In Stock | £36.04 |
                        StarTech.com 2m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable | In Stock | £40.20 |
                        StarTech.com 3m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable | In Stock | £45.82 |
                        StarTech.com 5m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable | In Stock | £58.65 |
