Connect 10GbE SFP+ network devices with this high-quality replacement SFP-H10GB-CU1M cable. The SFPCMM1M Cisco Compatible 1m SFP+ cable is a fully hot pluggable, direct attach cable, supporting 10 Gigabit Ethernet and Fiber Channel applications connected through (Small Form Factor Pluggable) SFP+ ports.
Designed for short length, high speed interconnects, this low power, low latency Twinax cable is a cost-effective alternative to fiber optic cable assemblies and is intended for short distance applications such as point-to-point in-rack and across rack network switch/server connections.
This 10GBASE-CU SFP+ Cable is compliant with MSA (Multi-Source Agreement) standards, making it a reliable replacement SFP-H10GB-CU1M cable.
Reliable technology
Utilizing twinaxial technology, this cable ensures reliable connectivity with minimal signal degradation, suitable for demanding networking environments. -
Secure connections
The latching connectors provide a secure fit, preventing accidental disconnections during operation and contributing to overall stability. -
Versatile compatibility
Compatible with SFP+ interfaces, this cable allows for easy integration with various networking devices, enhancing flexibility in network design. -
Environmentally friendly
This product meets RoHS compliance standards, reflecting a commitment to sustainability and safe usage.
- StarTech.com Cisco SFP-H10GB-CU1M Compatible 1m 10G SFP+ to SFP+ Direct Attach Cable Twinax, 10GbE SFP+ Copper DAC 10Gbps Low Power Passive Transceiver Module DAC, Cisco Firepower ASR920 - Lifetime Warranty (SFPCMM1M) - direct attach cable - 1 m
- Direct attach cable
- Technology
- Twinaxial
- Latching connectors
- Length
- 1 m
- Connector
- SFP+
- Connector (Second End)
- SFP+
- Limited lifetime warranty
- Designed For
- P/N: ET10GSFP, PEX10000SFPI, PEX10GSFP4I, PEX20000SFPI
- Network Cable Type
- Technology
- Twinaxial
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 30
- Impedance
- 100 Ohm
- Length
- 1 m
- Connector
- SFP+
- SFP+
- RoHS
- 0 °C
- 70 °C
- Designed For
StarTech.com 1m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable | In Stock | £38.05 |
StarTech.com 2m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable | In Stock | £40.56 |
StarTech.com 3m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable | In Stock | £46.24 |
StarTech.com 5m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable | In Stock | £60.13 |
