StarTech.com 3m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable
Quicklinx: 80HHWS00 Mfr#: N6PATC3MBL
Length: 3m
Colour: Blue
£8.22 ex VAT
£9.86 inc VAT
Express delivery Order within the next 13 hours for delivery tomorrow
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC3MBL Cat 6 Patch Cable (3m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance.
Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
StarTech.com Cat6 cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a cheaper cable based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
This Cat6 cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, StarTech.com cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
This Cat 6 patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com 3m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Blue, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC3MBL) - patch cable - 3 m - blue
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Pairs per Cable
4 pairs
Plated Connector
Gold
Molded, snagless
Length
3 m
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL - up to 500 MHz
80HH StarTech.com 3m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £8.22
80HH StarTech.com 3m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £5.42
80HH StarTech.com 3m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £5.47
80HH StarTech.com 3m Orange Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £6.15
80HH StarTech.com 3m Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £8.80
80HH StarTech.com 3m White Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £5.60
80HH StarTech.com 3m Yellow Cat6 Patch Cable In Stock £5.58
80HH StarTech.com 3m Green Cat6 Patch Cable In Stock £6.02
80HH StarTech.com 3m Purple Cat6 Patch Cable In Stock £5.60
Length: 3m
Colour: Blue
