Connect 40GBase-SR4, 100GBase-SR10, SFP+ and QSFP+ transceivers in 40 and 100 Gigabit networks. This fiber optic cable lets you connect 40GBase-SR4, 100GBase-SR10, SFP+ and QSFP+ transceivers in 40 and 100 Gigabit networks. The OM4 cable supports Vertical Cavity Surface Emitting Laser (VCSEL) and LED light sources and is backward compatible with your existing 50/125 equipment.
This Aqua OM4 duplex multimode fiber cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. It's ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each OM4 fiber cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
High-performance design
Featuring laser-optimized multimode fiber, this cable enhances data transmission efficiency and minimizes signal loss over distances. -
Advanced technology
Equipped with VCSEL array technology, this cable provides effective data handling and increased bandwidth for demanding applications. -
Durable construction
The low smoke zero halogen jacket material ensures safety and durability, making it suitable for various environments where safety is a concern. -
Efficient connectivity
With both left and right connectors utilizing LC multi-mode interfaces, the cable allows for seamless connections with compatible devices. -
Robust performance
With a tested frequency of up to 3500 MHz, this cable is designed to meet the needs of high-speed networking applications.
- StarTech.com Aqua OM4 Duplex Multimode Fiber - 3m/ 9 ft - 100 Gb - 50/125 - OM4 Fiber - LC to LC Fiber Patch Cable (450FBLCLC3) - network cable - 3 m - aqua
- Network cable - OM4
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Laser-optimized multimode fibre (LOMMF), VCSEL array technology
- Length
- 3 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- 2 x LC multi-mode - male
- Connector (Second End)
- Aqua
- Limited lifetime warranty
- Network Cable Type
- Technology
- Multimode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- 50 / 125 micron
- Length
- 3 m
- Aqua
- Connector
- Up to 3500 MHz
StarTech.com 1m Aqua OM4 LC Fiber Cable | In Stock | £18.15 |
StarTech.com 2m Aqua OM4 LC Fiber Cable | In Stock | £19.80 |
StarTech.com 5m Aqua OM4 LC Fiber Cable | In Stock | £22.30 |
StarTech.com 3m Aqua OM4 LC Fiber Cable | In Stock | £22.65 |
StarTech.com 10m OM4 LC Multimode Duplex Fiber Optic Patch Cable Aqua | In Stock | £39.85 |
StarTech.com 7m OM4 LC Multimode Duplex Fiber Optic Patch Cable - Aqua | In Stock | £32.25 |
StarTech.com 15m OM4 LC-LC Multimode Duplex Fiber Optic Patch Cable Aqua | In Stock | £52.42 |
