Connect 40GBase-SR4, 100GBase-SR10, SFP+ and QSFP+ transceivers in 40 and 100 Gigabit networks. This fiber optic cable lets you connect 40GBase-SR4, 100GBase-SR10, SFP+ and QSFP+ transceivers in 40 and 100 Gigabit networks. The OM4 cable supports Vertical Cavity Surface Emitting Laser (VCSEL) and LED light sources and is backward compatible with your existing 50/125 equipment.
This Aqua OM4 duplex multimode fiber cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. It's ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each OM4 fiber cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
Efficient data transmission
The Aqua OM4 Duplex Multimode Fiber Patch Cable is designed to facilitate high-speed communication, making it suitable for applications that require excessive bandwidth and minimal signal loss. -
Laser-optimized multimode fiber
This cable features laser-optimized multimode fiber (LOMMF) that enhances the performance of 100 Gb networks, ensuring faster and more reliable data transfers. -
Safety-focused jacket material
Constructed with a low smoke zero halogen (LSZH) jacket, this cable limits harmful smoke emissions during a fire, ensuring safety in indoor environments. -
Versatile duplex mode
The duplex mode of this cable allows for simultaneous transmission and reception of data, significantly increasing network efficiency and performance. -
Secure LC connectors
With LC connectors on both ends, the cable provides a secure connection, minimizing the risk of accidental disconnections in active network setups.
- StarTech.com Aqua OM4 Duplex Multimode Fiber - 1m / 3 ft - 100 Gb - 50/125 - OM4 Fiber - LC to LC Fiber Patch Cable (450FBLCLC1) - network cable - 1 m - aqua
- Network cable - OM4
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Laser-optimized multimode fibre (LOMMF)
- Length
- 1 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- 2 x LC multi-mode - male
- Connector (Second End)
- Aqua
- Limited lifetime warranty
- Network Cable Type
- Technology
- Multimode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- 50 / 125 micron
- Length
- 1 m
- Aqua
- Connector
StarTech.com 1m Aqua OM4 LC Fiber Cable | In Stock | £18.27 |
StarTech.com 2m Aqua OM4 LC Fiber Cable | In Stock | £19.60 |
StarTech.com 5m Aqua OM4 LC Fiber Cable | In Stock | £22.07 |
StarTech.com 3m Aqua OM4 LC Fiber Cable | In Stock | £23.25 |
StarTech.com 10m OM4 LC Multimode Duplex Fiber Optic Patch Cable Aqua | In Stock | £40.18 |
StarTech.com 7m OM4 LC Multimode Duplex Fiber Optic Patch Cable - Aqua | In Stock | £32.53 |
StarTech.com 15m OM4 LC-LC Multimode Duplex Fiber Optic Patch Cable Aqua | In Stock | £52.85 |
StarTech.com 10m OM4 Multimode Fiber Cable | In Stock | £33.56 |
StarTech.com 1m OM4 Multimode Fiber Cable | In Stock | £16.02 |
StarTech.com 2m OM4 Multimode Fiber Cable | In Stock | £18.25 |
StarTech.com 3m OM4 Multimode Fiber Cable | In Stock | £19.78 |
StarTech.com 5m OM4 Multimode Fiber Cable | In Stock | £23.60 |
StarTech.com 7m OM4 Multimode Fiber Cable | In Stock | £27.04 |
