Connect USB 10Gbps source and peripheral devices using this 9.8ft (3m) Active USB Type-C Cable. This cable is ideal for setups requiring full-featured USB-C and DP 1.4 support, such as large UHD displays/video walls, and boardroom/conference room cameras.
Versatile Compatibility
The USB-C to C cable enables universal compatibility with USB 3.2, USB 3.0, and USB-C devices. An integrated active chipset facilitates bi-directional connectivity for convenient setup, and supports up to 10Gbps throughput without additional power or signal boosters. -
Experience 4K Video with DisplayPort 1.4 Alt Mode
The Active USB-C cable supports up to 8K 60Hz video over DisplayPort 1.4 Alt Mode with HBR3, HDR10, MST, DSC 1.2, and HDCP 2.2. It is backward compatible with DP 1.3/1.2 resolutions, including 4K 60Hz, 1440p, and 1080p. -
Full-Featured USB-C Power and Data
The long Active USB-C Cable supports a data bandwidth of up to 10 Gbps. A certified E-marker chip ensures consistent Power Delivery of up to 60W. Dock and charge a USB-C laptop, such as Apple MacBook, Lenovo ThinkPad, or Microsoft Surface using a single USB-C connection that extends beyond the length of passive cables.
- StarTech 3m (10ft) Active USB-C Cable, USB 3.2 Gen 2 10Gbps, Long USB Type-C Data Transfer Cable, 60W Power Delivery, 8K 60Hz, DP 1.4 Alt Mode w/HBR3/HDR10/MST/DSC 1.2/HDCP 2.2 - USB C to C cable (UCC-3M-10G-USB-CABLE) - USB-C cable - USB-C to USB-C - 3 m
- USB-C cable
- Active cable, USB Power Delivery (60W), 8K60Hz support, HBR3 support, Display Stream Compression 1.2 (DSC), ABS connector housing, HDR10 support, 10 Gbps data rate, Power Delivery 3.0 (PD 3.0) technology, MST support, DisplayPort Alternate Mode 1.4 support
- Cable Length
- 3 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- USB 3.0 / USB 3.1 / USB 3.2 Gen 2
- Black
- 2-year warranty
- USB-C cable
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 29
- Plated Connector
- Nickel
- Cable Length
- 3 m
- Outside Diameter
- 6.2 mm
- Black
- 400 g
- Connector
- USB 3.0 / USB 3.1 / USB 3.2 Gen 2, RoHS, WEEE, EMI, HDCP 2.2
- Shipping Width
- 19 cm
- Shipping Depth
- 21 cm
- Shipping Height
- 3.2 cm
- 2-year warranty
StarTech.com Under Desk Cable Management Tray - Cord/Wire Organizer | In Stock | £21.05 |
StarTech.com Cable Management Sleeve | In Stock | £10.45 |
StarTech.com Hook and Loop Cable Ties 50pk | In Stock | £6.57 |
