Bundle PC cables, organize and secure office/server cable runs, and improve airflow around mission-critical equipment, using this 50-pack of 6in Hook-and-Loop Cable Ties.
Hassle-Free Cable Management
The hook and loop fastener straps provide a solution for bundling and/or securing. Protect equipment by reducing cable/connector strain. Bundle cables to improve airflow in high-density cabling environments, such as data centers and server rooms. -
Flexible Use
The hook-and-loop strips can be used to bundle and bind IT tools. In addition, the cable ties can be used to secure cable raceways to office desks and server room equipment. The reusable tie wraps are easy to apply, adjust, and remove. These ties offer a reusable and modular means of bundling and securing cables, an advancement over traditional zip ties This product is backed for 2 years, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com 6in Hook and Loop Cable Ties, 50 Pack, Black, Reusable Cable Straps, Adjustable and Flexible, Cord Organizer Tie/Wraps for Professional Cable Management - Wire Loop Ties (B506I-HOOK-LOOP-TIES) - cable tie - hook and loop
- Product Type
- Cable tie - hook and loop
- Packaged Quantity
- 50 (specifications are for single item)
- 1.2 cm
- Length
- 15 m
- Product Material
- Nylon
- Black
- 2-year warranty
- Packaged Quantity
- Product Type
- Product Material
- Nylon
- 1.2 cm
- Length
- 15 m
- Enclosure Colour
- Black
- Reusable, flexible
- Shipping Width
- 19.8 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 84.3 g
- Limited warranty - 2 years ¦ Technical support - assistance - lifetime
- -10 °C
- 80 °C
