StarTech.com 3m 9.8ft 10G SFP+ DAC Cable
Quicklinx: D9TDWS00 Mfr#: JD097CST
Length: 3m
Colour: Black
Hurry, only 2 left in stock!
£33.70 ex VAT
£40.44 inc VAT
Connect your HP 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack and across-rack network switch or server connections.
StarTech.com HPE JD097C Compatible 3m 10G SFP+ to SFP+ DAC Twinax, 10GbE SFP+ Copper DAC 10 Gbps Low Power Passive Mini GBIC/Transceiver Module DAC Firepower A5500, 10GE Copper SFP+ Cable - Lifetime Warranty (JD097CST) - 10GBase direct attach cable - 3 m - black
10GBase direct attach cable - SFF-8431/SFF-8432
Twinaxial
Passive cable
Length
3 m
Connector
SFP+ - latched
Connector (Second End)
SFP+ - latched
HP JD097C
Network Cable Type
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
30
Impedance
100 Ohm
Passive cable
Length
3 m
130 g
Connector
SFP+ - latched
SFP+ - latched
HP JD097C
FCC, RoHS, MSA
70 °C
D9TD StarTech.com 1m 3.3ft 10G SFP+ DAC Cable In Stock £32.89
D9TD StarTech.com 3m 9.8ft 10G SFP+ DAC Cable In Stock £43.55
D9TD StarTech.com 7m 23ft 10G SFP+ DAC Cable In Stock £59.35
D9TD StarTech.com 0.65m 2.1ft 10G SFP+ DAC Cable In Stock £24.04
D9TD StarTech.com 3m 9.8ft 10G SFP+ DAC Cable In Stock £33.70
D9TD StarTech.com 5m 16.4ft 10G SFP+ DAC Cable In Stock £40.34
Length: 3m
Colour: Black
