Connect your HP 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack and across-rack network switch or server connections.
 - StarTech.com HPE JG081C Compatible 5m 10G SFP+ to SFP+ Direct Attach Cable Twinax, 10GbE SFP+ Copper DAC 10Gbps Low Power Passive Mini GBIC/Transceiver Module DAC, Firepower, 5500, SFP+ - Lifetime Warranty (JG081CST) - 10GBase direct attach cable - 5 m - black
 - 10GBase direct attach cable - SFF-8431/SFF-8432
- Technology
 - Twinaxial
 - Passive cable
- Length
 - 5 m
- Connector
 - SFP+ - latched
- Connector (Second End)
 - SFP+ - latched
 - Black
- OEM Manufacturer Equivalent Part Number
 - HP JG081C
 - 2-year warranty
- Network Cable Type
- Technology
 - Twinaxial
- Jacket Material
 - PVC
- American Wire Gauge (AWG)
 - 24
- Impedance
 - 100 Ohm
 - Passive cable
- Length
 - 5 m
 - 316 g
 - Black
- Connector
 - SFP+ - latched
 - SFP+ - latched
 - HP JG081C
 - FCC, RoHS, MSA
 - 2-year warranty
 - 0 °C
 - 70 °C
                        StarTech.com 1m 3.3ft 10G SFP+ DAC Cable | In Stock | £32.59 |
                        StarTech.com 3m 9.8ft 10G SFP+ DAC Cable | In Stock | £42.49 |
                        StarTech.com 7m 23ft 10G SFP+ DAC Cable | In Stock | £55.26 |
                        StarTech.com 0.65m 2.1ft 10G SFP+ DAC Cable | In Stock | £23.46 |
                        StarTech.com 3m 9.8ft 10G SFP+ DAC Cable | In Stock | £32.89 |
                        StarTech.com 5m 16.4ft 10G SFP+ DAC Cable | In Stock | £39.35 |
