Power your USB Type-C devices over longer distances. With up to 5A (100W) of power output, you can use this USB-C to USB-C cable to power and charge a USB-C laptop, such as your Apple MacBook Pro, MacBook or Chromebook Pixel, using a USB-C wall charger, car charger or power bank. Or, you can power your laptop from a USB-C docking station.
The 5A of Power Delivery lets you charge your mobile devices faster than with a regular USB-C 2.0 cable, which is perfect for people on the move. Decrease your charge times and make sure your mobile devices are ready, whenever you need them while you're on the road.
The long cable lets you overcome distance restrictions and stay connected. You can take notes in a boardroom, catch up on emails in your hotel room, or read in a coffee shop.
The USB Type-C cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, which ensures a reliable and high-quality cable for all of your USB-C devices.
Reliable connectivity
This USB C To USB C cable is compliant with Thunderbolt 3 and USB 2.0 standards, ensuring a dependable connection for various devices. -
Efficient power delivery
With a rated current of 5 A and support for up to 100 W, this cable can charge devices quickly, maximizing performance and efficiency. -
Robust construction
The aluminum mylar foil and braid shielding combined with a PVC jacket provide superior protection against wear and tear, ensuring long-lasting use.
- StarTech.com USB C To USB C Cable - 10 ft / 3m - USB-IF Certified - 5A PD - USB 2.0 - USB Type C Charging Cable - USB C Fast Charge Cable (USB2C5C3M) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 3 m
- USB-C cable
- Technology
- Double shielded
- Up to 100 Watts of power delivery
- Length
- 3 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Rated Current
- 5 A
- Thunderbolt 3 / USB 2.0
- Black
- 2-year warranty
- USB-C cable
- Technology
- Double shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24/26
- Rated Current
- 5 A
- Length
- 3 m
- Black
- 135 g
- Connector
- Thunderbolt 3 / USB 2.0, RoHS, USB-IF, WEEE
- 2-year warranty
StarTech.com 4m USB 2.0 C Cable w/ PD (5A) | In Stock | £15.43 |
StarTech.com 3m 10ft USB C Cable w/ 5A PD | In Stock | £18.64 |
StarTech.com 1m 3ft USB C Cable w/ 5A PD | In Stock | £10.20 |
StarTech.com USB 2.0 - C to C w/ 5A PD - 6 ft / 2m | In Stock | £14.97 |
StarTech.com 2m USB 2.0 Certified Power Delivery(5A) C to C White Cable | In Stock | £13.77 |
StarTech.com 4m USB 2.0 Power Delivery(5A) C to C White Cable - M/M | In Stock | £13.90 |
StarTech.com 50cm USB 2.0 Power Delivery(5A) C to C Cable - M/M | In Stock | £9.63 |
Customer reviews
Write a review for the StarTech.com 3m 10ft USB C Cable w/ 5A PD here!
Only supports USB 2.0 standard
Reviewed by Anonymous Review Posted 12/03/2019
This cable does not support USB3.1 as I would expect for a USB-C cable. It only supports USB2.0. It therefore can only be used for data transfer and charging a laptop or phone. It does not support video out which is what I was looking for.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
