StarTech.com 4m USB 2.0 Power Delivery(5A) C to C White Cable - M/M
Quicklinx: DZ76WS00 Mfr#: USB2C5C4MW
Length: 4m
10 In Stock
£15.50 ex VAT
£18.60 inc VAT
With up to 5A (100W) of power output, you can use this USB-C to USB-C cable to power and charge a USB-C laptop, such as your Apple MacBook Pro, MacBook or Chromebook Pixel, using a USB-C wall charger, car charger or power bank. Or, you can power your laptop from a USB-C docking station.
The 5A of Power Delivery lets you charge your mobile devices faster than with a regular USB-C 2.0 cable, which is perfect for people on the move. Decrease your charge times and make sure your mobile devices are ready whenever you need them while you're on the road.
The long cable lets you overcome distance restrictions and stay connected. You can take notes in a boardroom, catch up on emails in your hotel room, or read in a coffee shop.
The USB Type-C cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, which ensures a reliable and high-quality cable for all of your USB-C devices.
  • Durable construction
    The cable features aluminum mylar foil with braid shielding, enhancing durability and reducing external interference.
  • Versatile compatibility
    Designed with 24-pin USB-C connectors on both ends, this cable is compatible with a wide range of USB-C devices.
  • Efficient charging
    With a rated current of 5 A, this cable enables efficient and rapid charging for devices that support high power delivery.
  • Environmentally friendly
    The cable complies with RoHS, USB-IF, and WEEE standards, ensuring it meets environmental safety requirements.
  • Enhanced performance
    This shielded USB-C cable allows for charging and supports data syncing, making it a versatile accessory.
StarTech.com USB C to USB C Cable - 13 ft / 4m - 5A PD - M/M - White - USB 2.0 - USB-IF Certified - USB Type C Cable - USB C Charging Cable (USB2C5C4MW) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 4 m
USB-C cable
Shielded
Sync and charge, up to 100 Watts of power delivery
Length
4 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Current
5 A
USB / USB 2.0
White
USB-C cable
Shielded
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
24/26
Rated Current
5 A
Plated Connector
Nickel
Length
4 m
White
180 g
Connector
24 pin USB-C - male
24 pin USB-C - male
USB / USB 2.0, RoHS, USB-IF, WEEE
DZ76 StarTech.com 4m USB 2.0 C Cable w/ PD (5A) In Stock £17.53
DZ76 StarTech.com 3m 10ft USB C Cable w/ 5A PD In Stock £19.10
DZ76 StarTech.com 1m 3ft USB C Cable w/ 5A PD In Stock £11.14
DZ76 StarTech.com USB 2.0 - C to C w/ 5A PD - 6 ft / 2m In Stock £15.26
DZ76 StarTech.com 2m USB 2.0 Certified Power Delivery(5A) C to C White Cable In Stock £13.94
DZ76 StarTech.com 50cm USB 2.0 Power Delivery(5A) C to C Cable - M/M In Stock £10.21
Length: 4m
