StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad
Quicklinx: 9F61WS00 Mfr#: USBLT3MW
Length: 3m
Colours:
More than 50 in stock
£19.06 ex VAT
£22.87 inc VAT
Charge and Sync your Apple Lightning-equipped devices over longer distances. The USBLT3MW 10ft/3m Lightning to USB Cable for iPhone, iPod and iPad enables long-range syncing and charging of your Lightning-enabled mobile digital devices - making it ideal for people on the move who need to access their device while it's charging. The cable features heavy gauge (20 AWG) wire for overcoming distance restrictions and allowing for full charging power at a distance of up to 3m, with no loss of charge time.
The reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
StarTech.com 3m (10ft) Long White Apple® 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad - Charge and Sync Cable (USBLT3MW) - Lightning cable - 3 m
Cable
Lightning cable - Lightning / USB
American Wire Gauge (AWG)
20/28
Length
3 m
White
Connector
Lightning - male
Connector (Second End)
USB - male
Sync and charge
P/N: BOX4CABLE, BOX4HDECP, BOX4HDECP2, MOD4AVHD, MOD4AVHDBT, MOD4DOCKACPD, ST1030USBM, ST73007UA, USB2PCARBK, USB2PCARBKS, USBLT2PCARW, USBUB2PCARB
Cable Type
Lightning cable
Interface Supported
Lightning / USB
20/28
Jacket Material
PVC
Shielding Material
Length
3 m
Plated Connector
Nickel
Sync and charge
White
Connector
Apple Lightning - male
4 pin USB Type A - male
RoHS
9F61 StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £13.64
9F61 StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £14.74
9F61 StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £19.06
Length: 3m
Stock Status: In stock
