StarTech.com 3m (10ft) Long Black Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad
Quicklinx: 9F60WS00 Mfr#: USBLT3MB
Length: 3m
Colours:
£18.04 ex VAT
£21.64 inc VAT
Charge and Sync your Apple Lightning-equipped devices over longer distances. The USBLT3MB 10ft/3m Lightning to USB Cable for iPhone, iPod and iPad is colored to suit your black mobile devices and enables long-range syncing and charging of your Lightning-enabled mobile digital devices - making it ideal for people on the move who need to access their device while it's charging. The cable features heavy gauge (20 AWG) wire for overcoming distance restrictions and allowing for full charging power at a distance of up to 3m, with no loss of charge time.
The reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
StarTech.com 3m (10ft) Long Black Apple® 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad - Charge and Sync Cable (USBLT3MB) - Lightning cable - Lightning / USB - 3 m
Cable
American Wire Gauge (AWG)
20/28
Length
3 m
Connector
Lightning - male
Connector (Second End)
USB - male
Sync and charge
P/N: BOX4CABLE
Cable Type
Lightning cable
Interface Supported
Lightning / USB
20/28
Jacket Material
PVC
Shielding Material
Length
3 m
Plated Connector
Nickel
Sync and charge
Connector
Apple Lightning - male
4 pin USB Type A - male
RoHS
P/N: BOX4CABLE
9F60 StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £15.14
9F60 StarTech.com 1m (3ft) Black Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £13.56
9F60 StarTech.com 2m (6ft) Long Black Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £14.91
9F60 StarTech.com 3m (10ft) Long Black Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £18.04
9F60 StarTech.com USB Wall Charger 17W / 3.4A x2 In Stock £13.05
Length: 3m
