StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad
Quicklinx: 9F61WS00 Mfr#: USBLT3MW
Length: 3m
Colours:
10 In Stock
£17.97 ex VAT
£21.56 inc VAT
Charge and Sync your Apple Lightning-equipped devices over longer distances. The USBLT3MW 10ft/3m Lightning to USB Cable for iPhone, iPod and iPad enables long-range syncing and charging of your Lightning-enabled mobile digital devices - making it ideal for people on the move who need to access their device while it's charging. The cable features heavy gauge (20 AWG) wire for overcoming distance restrictions and allowing for full charging power at a distance of up to 3m, with no loss of charge time.
The reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
  • Durable construction
    The cable features an aluminum mylar foil with a braid that enhances resistance to wear and tear while providing optimal performance for charging and syncing.
  • Extended length
    At 3 m (10 ft), this cable allows users to move freely while charging or syncing, making it ideal for various settings, from home to office.
  • Versatile compatibility
    Equipped with a male Apple Lightning connector and a male 4-pin USB Type-A connector, this cable works with a wide array of Apple devices, offering seamless connectivity.
  • High-quality materials
    The PVC jacket and nickel-plated connectors ensure longevity and consistent performance, making this cable a reliable choice for all charging and syncing needs.
  • Resilient wiring
    Constructed with 20/28 American Wire Gauge, the cable is designed to handle the requirements of high-performance charging and data transmission.
StarTech.com 3m (10ft) Long White Apple® 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad - Charge and Sync Cable (USBLT3MW) - Lightning cable - Lightning / USB - 3 m
Cable
American Wire Gauge (AWG)
20/28
Length
3 m
White
Connector
Lightning - male
Connector (Second End)
USB - male
Sync and charge
P/N: BOX4CABLE, BOX4HDECP, BOX4HDECP2, KITBXAVHDPEU, KITBXAVHDPNA, KITBXAVHDPUK, KITBXDOCKPEU, KITBXDOCKPNA, KITBXDOCKPUK, KITBZDOCK, MOD4AVHD, MOD4AVHDBT, MOD4DOCKACPD, ST1030USBM, ST73007UA, USB2PCARBK, USB2PCARBKS, USBLT2PCARW, USBUB2PCARB
Cable Type
Lightning cable
Interface Supported
Lightning / USB
20/28
Jacket Material
PVC
Shielding Material
Length
3 m
Plated Connector
Nickel
Sync and charge
White
Connector
Apple Lightning - male
4 pin USB Type A - male
RoHS
9F61 StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £14.23
9F61 StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £15.14
9F61 StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £17.97
9F61 StarTech.com USB Wall Charger 17W / 3.4A x2 In Stock £13.05
Length: 3m
