StarTech.com 3ft USB to RS232 DB9 Serial Adapter Cable - M/M
Quicklinx: 7NZ6WS00 Mfr#: ICUSB232SM3
Type: Serial adapter
Compatibility: Mac, PC
Interface: USB 2.0
More than 50 in stock
£14.96 ex VAT
£17.95 inc VAT
The ICUSB232SM3 3ft USB to Serial Adapter Cable lets you connect DB9 RS232 serial devices to your Mac or PC laptop or desktop computer through an available USB port, as though the computer offered an onboard DB9M connector.
Unlike typical USB to serial converter cables where the conversion takes place at the DB9 end of the cable, the StarTech.com ICUSB232SM3 features a converter chip on the USB end. Converting at the USB source overcomes the 15ft. technical limit of USB cables, allowing for a much greater serial DB-9 extension cable (50ft.+ is possible depending on the application), should it be necessary for a given setup.
Simple to install and use, this USB to Serial adapter provides a cost-effective solution that bridges the compatibility gap between modern computers and legacy serial peripherals.
StarTech.com 3ft USB to RS232 DB9 Serial Adapter Cable - Up to 1 Mbps USB to Serial Converter - M/M USB to VGA Adapter (ICUSB232SM3) - serial adapter - USB 2.0 - RS-232
Serial adapter
External
Interface (Bus) Type
USB 2.0
Ports
RS-232
Length
91.44 cm
42 g
RS-232
Data Transfer Rate
1 Mbps
Prolific PL-2303HX
Microsoft Windows 98 Second Edition, Microsoft Windows Server 2003, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows 2000 / ME / XP, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.14, Microsoft Windows CE 5.2
Serial adapter
External
USB 2.0
Ports
RS-232
Wired
RS-232
Data Transfer Rate
1 Mbps
USB powered
Processor / Memory
Prolific PL-2303HX
1 x RS-232 - 9 pin D-Sub (DB-9) - male
RoHS
Length
91.44 cm
42 g
Limited warranty - lifetime
-20 °C
80 °C
7NZ6 StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.84
7NZ6 StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.53
7NZ6 StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention In Stock £21.00
7NZ6 StarTech.com 4 Port Wall Mountable USB to Serial Adapter Hub with COM Retention In Stock £62.68
7NZ6 StarTech.com 8 Port USB to RS232 Serial DB9 Adapter Hub In Stock £134.94
7NZ6 StarTech.com 3ft USB to RS232 DB9 Serial Adapter Cable - M/M In Stock £14.96
7NZ6 StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £4.19
7NZ6 StarTech.com 4 Port USB to Serial Hub In Stock £53.22
Compatibility: Mac
Compatibility: PC
Interface: USB 2.0
Price Range Ex VAT: 0 - 50
