StarTech.com 36U Adjustable 4 Post Server Equipment Open Frame Rack Cabinet
Quicklinx: 6B9PWS00 Mfr#: 4POSTRACK36
Store your servers, network and telecommunications equipment in this adjustable 36U open-frame rack. The 4POSTRACK36 Adjustable Depth 36U 4-Post Rack provides a durable, open frame housing for rackmount servers and networking equipment. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
The equipment cabinet features heavy gauge mounting rails to ensure a stable installation platform and adjustable posts for flexible installation.
The 36U rack is compliant with EIA-RS-310C standards, offering a universal design that's compatible with equipment from popular manufacturers. Plus, the equipment rack is flat-packed, reducing shipping costs and simplifying handling and assembly.
For added versatility, StarTech.com offers an optional 4 Piece Caster Ki (4POSTCASTER) that can be installed on the bottom of the 36U server rack, making it easier to re-position the cabinet/rack as needed for future uses.
StarTech.com 36U Heavy Duty Open Frame Server Rack - 1000lbs - 4 Post Adjustable Depth (18.3" to 39.2") Network Equipment Rack w/ Casters (4POSTRACK36) - rack - 36U
Rack
Height (Rack Units)
36U
Product Material
Steel
57.1 cm 171.2 cm
42 kg
P/N: CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224
Rack
Product Material
Steel
Height (Rack Units)
36U
57.1 cm
171.2 cm
42 kg
Weight Limit
450 kg
EIA-310-C, RoHS
Limited warranty: - lifetime
6B9P StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £94.63
6B9P StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £45.84
6B9P StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £79.46
6B9P StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
6B9P StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.71
6B9P StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £464.07
6B9P StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £351.41
6B9P StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
6B9P StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
6B9P StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
6B9P StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.30
6B9P StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf In Stock £91.54
6B9P StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £527.07
6B9P StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £280.59
6B9P StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £317.20
6B9P StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £543.36
6B9P StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £86.88
6B9P StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £100.69
6B9P StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £65.78
6B9P StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £75.35
6B9P StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £77.01
6B9P StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £15.50
6B9P StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £74.28
6B9P StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £81.75
6B9P StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £56.70
6B9P StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £44.28
6B9P StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.00
6B9P StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £51.38
6B9P StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
6B9P StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.68
6B9P StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.36
6B9P StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.59
6B9P StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £158.72
6B9P StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 125lbs / 56.7kg In Stock £162.18
6B9P StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £47.16
6B9P StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.75
6B9P StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.11
6B9P StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £58.68
6B9P StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
6B9P StarTech.com 25U 36in Server Rack Cabinet In Stock £730.55
6B9P StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
6B9P StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
6B9P StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £53.55
6B9P StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
6B9P StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
6B9P StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
6B9P StarTech.com 19in Cable Management Panel In Stock £24.18
6B9P StarTech.com 10-32 Server Rack Screws and Nuts - 50 Pack - Black - TAA Co In Stock £29.04
6B9P StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
6B9P StarTech.com 42U Server Rack Cabinet In Stock £1,258.59
