Connect a slimline SATA drive to a standard SATA motherboard connector. The SLSATAF36 Slimline SATA to SATA with LP4 Power Cable (36-inch) features a SATA data receptacle and a Molex (LP4) power connection on one end, and a Slimline Serial ATA receptacle on the other - allowing you to connect a slim SATA drive to a computer motherboard that does not have a Slimline connection available.
Supporting full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives, this innovative adapter cable provides you with the connections needed to simplify the migration to Slimline SATA-equipped drives.
- StarTech.com 36in Slimline SATA to SATA with LP4 Power Cable Adapter (SLSATAF36) - SATA cable - 91.4 cm
- SATA cable
- Interface Speed
- Serial ATA 150/300/600
- Length
- 91.4 cm
- Connectors
- 13 pin Slimline Serial ATA - female
- Connectors (Second End)
- 7 pin Serial ATA - female , 4 pin internal power (12V) - male
- Red
- Limited lifetime warranty
- Storage Cable Type
- SATA cable
- Interface Speed
- Length
- 91.4 cm
- Red
- Connectors
- RoHS
