Connect your MSA compliant 40GbE QSFP+ network devices with this cost-effective, active optical cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This active optical cable (AOC) is fully hot-pluggable and supports 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports. The AOC cable is lighter and more flexible than QSFP+ direct attach cables, which makes it ideal for installation in tight spaces and over longer distances.
Designed for high-speed interconnects, this low-power, low-latency optical cable is ideal for applications such as point-to-point across-rack network switch or server connections.
 - StarTech.com MSA Uncoded Compatible 30m/98.4ft 40G QSFP+ to QSFP+ AOC Cable, 40 GbE QSFP+ Active Optical Fiber, 40 Gbps QSFP Plus/Transceiver Module Cable, 40GE QSFP+ Active Optical Cable - Lifetime Warranty (QSFP40GAO30M) - 40GBase direct attach cable - 30 m - black
 - 40GBase direct attach cable - SFF-8436
- Technology
 - Fibre optic
 - Active cable
- Length
 - 30 m
- Connector
 - QSFP+ - latched
- Connector (Second End)
 - QSFP+ - latched
 - Black
 - 2-year warranty
- Network Cable Type
- Technology
 - Fibre optic
- Jacket Material
 - PVC
 - Active cable
- Length
 - 30 m
 - 1.1 kg
 - Black
- Connector
 - QSFP+ - latched
 - QSFP+ - latched
 - FCC, RoHS, MSA
 - 2-year warranty
 - 0 °C
 - 70 °C
