This 32.8 foot (10 meter) Active HDMI Cable with Ethernet establishes a connection between HDMI-enabled devices over long distances, ideal for in-home and office cable runs.
High-Speed HDMI Cable
This high-speed HDMI cable supports resolutions of up to 4K at 60Hz (4096 x 2160p), 18Gbps bandwidth, High Dynamic Range (HDR10), Audio Return Channel (ARC), and Dolby Vision, for high contrast ratios, and vivid color. -
Reliable Connections Over Long Distances
The cable features built-in amplifier circuitry, which actively boosts the HDMI signal, with no external power required. It is the perfect solution for longer transmissions without any signal loss. It features source and display labels on the connectors to ensure the display and source are properly connected. This product is backed for 2 years, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com 30ft (10m) Active HDMI Cable w/ Ethernet - HDMI 2.0 4K 60Hz UHD - Rugged HDMI Cord w/ Aramid Fiber - Durable High Speed HDMI Cable - Heavy-Duty HDMI 2.0 Cable - HDMI cable with Ethernet - 10 m
- Cable
- High Speed - HDMI cable with Ethernet
- American Wire Gauge (AWG)
- 28
- Length
- 10 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- 4K format support, HDR support, aramid reinforced core, strain relief, 100% copper cable, Spectra HT8181 chipset
- 2-year warranty
- Cable Type
- 28
- Jacket Material
- Thermoplastic elastomer (TPE)
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 10 m
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- RoHS, WEEE, BT.2020 Colorimetry, HDCP 2.2
- 700 g
- Shipping Width
- 33 cm
- Shipping Depth
- 25.2 cm
- Shipping Height
- 12 cm
- Shipping Weight
- 700 g
- Limited warranty - 2 years
StarTech.com 23ft Active HDMI Cable | In Stock | £76.88 |
StarTech.com Active HDMI 2.0 Cable | In Stock | £142.66 |
StarTech.com Active HDMI 2.0 Cable | In Stock | £172.58 |
