StarTech.com 23ft Active HDMI Cable
Quicklinx: H23ZWS00 Mfr#: RH2A-7M-HDMI-CABLE
Length: 7m
Hurry, only 1 left in stock!
£80.05 ex VAT
£96.06 inc VAT
This 23 foot (7 meter) Active HDMI Cable with Ethernet establishes a connection between HDMI-enabled devices over long distances, ideal for in-home and office cable runs.
  • High-Speed HDMI Cable
    This high-speed HDMI cable supports resolutions of up to 4K at 60Hz (4096 x 2160p), 18Gbps bandwidth, High Dynamic Range (HDR10), Audio Return Channel (ARC), and Dolby Vision, for high contrast ratios, and vivid color.
  • Reliable Connections Over Long Distances
    The cable features built-in amplifier circuitry, which actively boosts the HDMI signal, with no external power required. It is the perfect solution for longer transmissions without any signal loss. It features source and display labels on the connectors to ensure the display and source are properly connected. This product is backed for 2 years, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 7m (23ft) Active HDMI Cable w/ Ethernet - HDMI 2.0 4K 60Hz UHD - Rugged HDMI Cord w/ Aramid Fiber - Durable High Speed HDMI Cable - Heavy-Duty HDMI 2.0 Cable - HDMI cable with Ethernet - 7 m
Cable
High Speed - HDMI cable with Ethernet
American Wire Gauge (AWG)
28
Length
7 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K format support, HDR support, 100% copper cable, Spectra HT8181 chipset, strain relief, aramid reinforced core
Cable Type
28
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
7 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS, WEEE, BT.2020 Colorimetry, HDCP 2.2
500 g
Shipping Width
33 cm
Shipping Depth
25.2 cm
Shipping Height
10 cm
Shipping Weight
500 g
H23Z StarTech.com 30ft Active HDMI Cable In Stock £89.02
H23Z StarTech.com Active HDMI 2.0 Cable In Stock £146.23
H23Z StarTech.com Active HDMI 2.0 Cable In Stock £176.89
Length: 7m
