StarTech.com 3 Port USB C 3.1 Gen 2 Hub with Ethernet Adapter
Quicklinx: FLXPWS00 Mfr#: HB31C2A1CGS
Type: USB
Ports: 3
Data Transfer Rate: [N/A]
Managed: No
POE: No
£66.45 ex VAT
£79.74 inc VAT
Expand the connectivity of your USB-C laptop with this new generation USB-C 3.1 Gen 2 hub offering 10Gbps supporting greater bus bandwidth to connected devices and faster data transfer speeds. This self-powered 3-Port USB-C hub plugs into the USB Type-C or Thunderbolt 3 port on your device, adding one LAN port, one USB-C port, and two USB-A ports, so you can quickly connect more USB devices.
For faster and more consistent network connections, the USB 3.1 Gen 2 hub's integrated Gigabit Ethernet port provides wired network access that is fully compatible with IEEE 802.3/u/ab standards. The GbE port also supports Wake-on-LAN (WoL), so you can remotely wake your computer over your network.
This compact, lightweight USB-Type-C hub is a convenient and compact addition to your laptop setup. The hub is self-powered and includes a universal power adapter to provide better support of USB devices, such as external storage, that may draw more power.
The USB-C host cable is detached and with an extended length of 3.3' (1 m), it provides more flexibility for longer reach connection requirements and plug and play installation.
For added flexibility and security, the mini hub features mounting holes to work with StarTech.com dock mounts such as SSPMSVESA or SSPMSUDWM.
With ports for both USB-C and USB-A peripherals, this hub is backwards compatible supporting both legacy and new USB devices. It features one always-on USB-A fast charge port which supports two modes of operation: Data transfer and charging when the laptop is connected and on dedicated or hostless charging which provides a higher charging current, when the host is off, on standby, or disconnected.
You can connect video capture devices, portable flash drives, and external hard drives, with fast data transfer speeds of up to 10 Gbps. This 3 port USB Type-C hub enhances your productivity, giving you the connections you need while you work or travel.
  • Gigabit Network Access
    For faster and more consistent network connections, the USB 3.2 Gen 2 hub's integrated Gigabit Ethernet port provides wired network access that is fully compatible with IEEE 802.3/u/ab standards. The GbE port also supports Wake-on-LAN (WoL), so you can remotely?wake your computer over your network.
  • Easy Setup?& Installation
    This compact, lightweight USB-Type-C hub is a convenient and compact addition to your laptop setup.?The hub is self-powered and includes a universal power adapter to provide better support of USB devices, such as external storage, that may draw more power. The USB-C host cable is detached and with an extended length of?3.3' (1 m), it provides more flexibility for longer reach connection requirements and plug and play installation.?? For added flexibility and security, the mini hub features mounting holes to work with StarTech.com dock mounts such as SSPMSVESA or SSPMSUDWM.
  • Connect?USB-C & USB-A?Peripherals
    With?ports?for?both USB-C and USB-A peripherals,?this hub is backwards compatible?supporting both legacy and new USB devices. It features one always-on USB-A fast charge port which supports two modes of operation: • Data transfer and charging when the laptop is connected and on • Dedicated or hostless charging which provides a higher charging current, when the host is off, on standby, or disconnected
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
  • The IT Pro's Choice Since 1985
    StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. HB31C2A1CGS?is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com 3 Port USB C 3.1 Gen 2 Hub with Ethernet Adapter, 10Gbps USB Type C to 2x USB-A & 1x USB-C Ports, USB Hub w/ BC 1.2 Phone Fast Charging, Superspeed 10Gbps USB C Hub with GbE - Windows/macOS/Linux - hub - 3 ports
Hub - 3 ports
Subtype
USB
Ports
1 x USB-C + 2 x USB 3.1 + 1 x 10/100/1000
Metal housing, UASP, USB Pass-Through, Fast Charging Port, DCP
USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2, USB 3.2 Gen 2
AC 110/240 V 2 A
10 cm x 6 cm x 2.5 cm
87 g
Black, space grey
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 (32/64-bits), Microsoft Windows Server 2016, Microsoft Windows 7 / 8.1 / 10 (32/64 bits), Ubuntu 14/15/16/17, Microsoft Windows Server 2019, Linux LTS versions only, Android 8.0 (Oreo) or later, Linux Kernel 4.x or later, Google Chrome OS 61 or later, Ubuntu 18, Ubuntu 19, Apple MacOS X 10.10 - 10.15, Apple iPadOS 13.1 or later, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0
Japan, New Zealand, North America, United Kingdom, Europe
P/N: PEXUSB321C
Hub - 3 ports
Enclosure Type
Desktop
Subtype
USB
Ports
X Realtek Semiconductor
1 x USB 3.1 Gen 2 Type C , 2 x USB 3.1 Gen 2 Type A , 1 x Gigabit LAN RJ-45
External power adapter
Power Provided
DC 12 V
AC 110/240 V
Electric Current Required
2 A
24 Watt
Black, space grey
1 x USB-C cable - 1 m
Plug and Play, FCC, RoHS, WEEE, REACH, UASP (USB Attached SCSI Protocol)
10 cm
6 cm
2.5 cm
87 g
Shipping Width
21.3 cm
Shipping Depth
14.9 cm
Shipping Height
5.1 cm
Shipping Weight
500 g
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
P/N: PEXUSB321C
FLXP StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £7.96
FLXP StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £11.06
FLXP StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £14.29
FLXP StarTech.com USB 3.0 USB-C to USB-A Adapter In Stock £8.05
FLXP StarTech.com 1m USB 3.1 C Cable w/ PD (5A) In Stock £25.63
FLXP StarTech.com 0.5m USB 3.1 C - Micro B Cable In Stock £10.54
FLXP StarTech.com 0.5m USB C Cable - USB 3.1 In Stock £14.73
FLXP StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £16.24
FLXP StarTech.com 4 -Port USB-C Hub 10 Gbps - 3x USB-A & 1x USB-C In Stock £33.73
FLXP StarTech.com 3-Port USB-C Hub with LAN Port - 10Gbps In Stock £55.93
FLXP StarTech.com 3-Port USB-C Hub with SD Card Reader - 10Gbps In Stock £48.70
FLXP StarTech.com Docking Station Mount - Wall Mount / Under-Desk Mounting Pla In Stock £9.31
FLXP StarTech.com Docking Station Mount - For StarTech.com Docks / Hubs - VESA In Stock £14.31
FLXP StarTech.com 4 -Port USB-C™ Hub 10 Gbps - 2x USB-A & 2x USB-C In Stock £43.84
FLXP StarTech.com 4 Port USB C Hub - 3 USB-A/1 USB-C (5Gbps USB 3.0) - 11.2" Cable In Stock £47.64
FLXP StarTech.com 4 Port USB C Hub 5Gbps - 4x USB-A - Bus Powered USB 3.0 Type-C Hub - 11in Cable In Stock £28.04
FLXP StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub In Stock £115.92
FLXP StarTech.com 4 Port USB C Hub 10Gbps In Stock £120.71
FLXP StarTech.com 4-Port USB-C Hub, 100W PD In Stock £38.20
FLXP StarTech.com Portable 4pt USB-C Hub, 10Gbps In Stock £32.62
FLXP StarTech.com Industrial USB 2.0 Hub In Stock £115.92
FLXP StarTech.com 10-Port USB-C Hub Self-Powered In Stock £115.46
FLXP StarTech.com 7-Port USB-C Hub, Self-Powered In Stock £106.95
FLXP StarTech.com 3-Port USB-C Hub, 2.5GbE, PD In Stock £55.30
FLXP StarTech.com USB-C/USB-A Hub - GbE - RS232 In Stock £66.08
Type: USB
Ports: 3
Managed: No
POE: No
