Add a unique combination of serial, USB and Ethernet ports to your laptop or PCThis USB Type-C Hub with RS-232 Serial, Gigabit Ethernet, and 100W USB-C Power Delivery Pass-Through adds two USB 3.2 Gen 1 (5Gbps) Type-A ports to a USB enabled computer. The attached 2ft (60cm) USB-C host cable includes a tethered USB-C to USB-A adapter that enables the USB Hub to easily connect to both USB-A and USB-C host computers.RS-232 SerialThe USB Hub adds an RS-232 serial DB/DE-9M (male) connector to a desktop or laptop. The USB to RS-232 adapter features COM retention, which automatically reassigns the COM port value if the cable is disconnected and reconnected, or if the system is rebooted.Gigabit EthernetThe USB hub features a Gigabit Ethernet Network Interface Controller (NIC). The Ethernet adapter is compatible with the IEEE 802.3u/ab standards and supports Wake-on-LAN (WoL), Jumbo Frames, and V-LAN Tagging. The network adapter enhances laptop network reliability, security, and performance, by utilizing wired 10/100/1000Mbps Ethernet.USB Power Delivery Pass-ThroughThis USB hub features 100W USB Power Delivery 3.0 pass-through (85W laptop charging). Connect a power source to the USB-C PD pass-through port to power the connected host device. PD 3.0 features Fast Role Swap (FRS) to prevent USB data disruption when switching power sources (USB-C power adapter to bus power).The USB hub features Overcurrent Protection (OCP) for added protection to the USB hub and any connected devices. OCP prevents faulty USB peripherals from drawing more power than is safely allocated.Plug and PlayThis device is compatible with most major operating systems, including Windows, macOS, and Linux. The Hub is automatically detected, configured, and installed upon connection to a host computer.
- StarTech.com 2-Port USB-C/USB-A Hub with GbE and RS232 Serial, 2x USB-A - hub - 2 ports
- Hub - 2 ports
- Subtype
- USB
- Ports
- 2 x USB 3.2 Gen 1
- Performance
- Data transfer rate: up to 5 Gbps , Baud rate: 115.2 Kbps
- Jumbo Frame Support
- 9KB
- Flow control, WOL, full duplex mode, PXE support, priority encoding, UASP, OCP support, 256-byte FIFO, EEE, VLAN Tagging, Auto MDIX, USB Power Delivery 3.0, FRS, bus powered
- IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- 12.8 cm x 5.5 cm x 1.9 cm
- 105 g
- Space grey
- System Requirements
- Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE .NET 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows CE .NET 6.0, Microsoft Windows CE .NET 5.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Linux Kernel 3.0 or later, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple macOS Big Sur 11.0, Microsoft Windows Server 2022, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8/8.1/10/11, Apple macOS Sonoma 14.0, Apple macOS 10.15 - 10.6
- 2-year warranty
- Hub - 2 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- 2 x USB 3.2 Gen 1
- Performance
- 9KB
- Processor
- X ASIX / VIA / FTDI VL817-Q7 / VL103-Q4 / AX88179A / FT232RL
- Status Indicators
- Port status
- 2 x USB 3.2 Gen 1 Type A , 1 x serial (RS-232) DB-9 COM retention support , 1 x 10/100/1000Base-T RJ-45 , 1 x USB-C (power delivery) 100 Watt
- Space grey
- Cables Included
- 1 x USB-C cable with USB-C to USB-A dongle - 60 cm
- RoHS, WEEE, RCM
- Software Included
- Connectivity Tools
- OS Required
- 12.8 cm
- 5.5 cm
- 1.9 cm
- 105 g
- Shipping Width
- 21.3 cm
- Shipping Depth
- 14.5 cm
- Shipping Height
- 3.4 cm
- Shipping Weight
- 171 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 0 - 95% RH
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
