StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop
PRICE DROP!
Clearance
Last Few Remaining
Price Drop
Quicklinx: C5SHWS00 Mfr#: HB30C3A1GE
Type: USB Hub
Interface: USB 3.1 Type C
Speed: 5Gbps
Ports: 3
Form Factor: External
£32.45 ex VAT
£38.94 inc VAT
Turn a USB Type-C port on your laptop into three USB Type-A ports (5Gbps) and one Gigabit Ethernet port. If you have a USB-C equipped laptop, but lack other important connection ports, then this hub can help. It couples your USB peripheral and RJ45 network connections into a single, convenient combination hub. USB 3.0 is also known as USB 3.1 Gen 1.
Through the USB-C host connector, this hub gives you three traditional USB-A ports, and a Gigabit Ethernet connection, making it a must-have laptop accessory. Plus, the integrated 30 cm (12 in.) cable lets you place the hub, your devices, and your network connection, exactly where you need them.
It's ideal for virtually any USB-C equipped laptop, such as the Chromebook Pixel, the Dell Latitude 11 5000 2-in-1, and Dell XPS 12.
This dynamic USB 3.0 hub integrates an easy-to-use USB Type-C connector. It's small and reversible, which makes for easier insertions, and you can connect the plug with either side facing up, which means less risk of damaging your ports and less frustration.
While your USB-C equipped laptop, or MacBook is lightweight and portable, it might be missing vital connectivity ports, such as wired Internet. Because this hub offers a Gigabit Ethernet port, you can connect to a network in locations were Wi-Fi is unreliable or unavailable.
With a small footprint and lightweight housing, you can easily tuck the hub and the included power adapter into your laptop bag to expand your connectivity when you're traveling.
Plus, the compact USB 3.0 hub takes up minimal space on a desk, so it fits perfectly in office, hot-desk (short-term guest), and BYOD workstation environments.
The hub's built-in USB cable is long enough to reach your laptop or tablet's USB 3.0 port, regardless of where the port is located. Now, you can eliminate the worry and frustration when your hub's built-in cable is too short and doesn't reach your laptop's USB port location.
Plus, the extended-length cable provides you with more desk placement options, which makes it easier to create a comfortable, space-efficient work area.
This easy-to-use hub is natively supported in most operating systems, and you can install it quickly, without having to install additional drivers or software. You can also avoid the nuisance and cost of purchasing new devices, by using the USB 3.0 hub with your current USB 2.0 and 1.x devices.
  • Take advantage of USB-C
    This dynamic USB 3.2 Gen 1 hub is TAA compliant and integrates an easy-to-use USB Type-C connector. It's small and reversible, which makes for easier insertions, and you can connect the plug with either side facing up, which means less risk of damaging your ports and less frustration. While your USB-C equipped laptop, or MacBook is lightweight and portable, it might be missing vital connectivity ports, such as wired Internet. Because this hub offers a Gigabit Ethernet port, you can connect to a network in locations were Wi-Fi is unreliable or unavailable.
  • Compact design for portability or permanent placement
    With a small footprint and lightweight housing, you can easily tuck the hub and the included power adapter into your laptop bag to expand your connectivity when you're traveling. Plus, the compact USB 3.2 Gen 1 hub takes up minimal space on a desk, so it fits perfectly in office, hot-desk (short-term guest), and BYOD workstation environments.
  • Extended-length cable eliminates aggravation
    The hub's built-in USB cable is long enough to reach your laptop or tablet's USB 3.2 Gen 1 port, regardless of where the port is located. Now, you can eliminate the worry and frustration when your hub's built-in cable is too short and doesn't reach your laptop's USB port location. Plus, the extended-length cable provides you with more desk placement options, which makes it easier to create a comfortable, space-efficient work area.
  • Save money and time
    This easy-to-use hub is natively supported in most operating systems, and you can install it quickly, without having to install additional drivers or software. You can also avoid the nuisance and cost of purchasing new devices, by using the USB 3.2 Gen 1 hub with your current USB 2.0 and 1.x devices. The HB30C3A1GE is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com 3 Port USB C Hub with Ethernet - USB-C to 3x USB-A w/ Power Adapter & Gigabit Ethernet - Thunderbolt 3 Compatible - USB C Network Adapter (HB30C3A1GE) - hub - 3 ports
Hub - 3 ports
Subtype
USB
Ports
3 x SuperSpeed USB 3.0 + 1 x 10/100/1000
Jumbo frame size: 4096
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), Energy Efficient Ethernet, priority encoding
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, USB 1.1, USB 2.0, USB 3.0, IEEE 802.3az
AC 120/230 V / DC 5 V
4.5 cm x 8.7 cm x 1.4 cm
44 g
Microsoft Windows Server 2003, Linux 2.6.x or later, Microsoft Windows Server 2008 R2, Google Chrome OS, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 11.3 or later
Australia, North America, United Kingdom, Europe
Hub - 3 ports
Enclosure Type
Desktop
Subtype
USB
Ports
X Genesys Logic / ASIX GL3522 / AX88179
Status Indicators
Link/activity
3 x USB 3.0 Type A , 1 x 1000Base-T RJ-45
External power adapter
10 Watt
1 x USB 3.1 cable - 30 cm
FCC, RoHS, WEEE, RCM
4.5 cm
8.7 cm
1.4 cm
44 g
50 °C
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
C5SH StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - White In Stock £37.08
C5SH StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable In Stock £38.80
C5SH StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.61
C5SH StarTech.com USB-C to Gigabit Adapter In Stock £23.46
C5SH StarTech.com 4 Port USB 3.0 Hub - USB-C Hub In Stock £29.84
C5SH StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £8.63
C5SH StarTech.com 3Pt Portable USB 3.0 Hub + GbE In Stock £33.70
C5SH StarTech.com USB-C to Gigabit Adapter In Stock £35.99
C5SH StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop In Stock £32.45
C5SH StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White In Stock £25.61
C5SH StarTech.com 4 Port USB 3.0 C Hub - C to A In Stock £27.39
C5SH StarTech.com 4 Port USB C Hub with PD 2.0 In Stock £34.11
C5SH StarTech.com 3PT USB 3.0 C Hub + GbE PD 2.0 In Stock £45.82
C5SH StarTech.com 4 Port USB 3.0 C Hub - C to A In Stock £36.34
C5SH StarTech.com 4 Port USB C Hub - C to C & A In Stock £26.12
C5SH StarTech.com 7 Port USB C Hub - C to C & A In Stock £65.16
C5SH StarTech.com 7 Port USB-C Hub - C to C & A In Stock £67.97
C5SH StarTech.com 4-Port USB-C Hub - USB 3.1 In Stock £33.92
C5SH StarTech.com 4-Port USB 3.0 Hub with On/Off In Stock £23.64
C5SH StarTech.com 4 Port USB 3.0 Hub USB-C to 4x USB-A In Stock £30.53
C5SH StarTech.com 3-Port USB-C Hub, 2.5GbE, PD In Stock £52.47
C5SH StarTech.com USB-C/USB-A Hub - GbE - RS232 In Stock £62.68
Type: USB Hub
Speed: 5Gbps
Ports: 3
