USB Type C Hub , Bus-powered. Expand the connectivity of your USB-C laptop with this new-generation USB-C 10G hub. It plugs into your laptop's USB Type-C or Thunderbolt 3 port, adding four USB 3.1 Gen 2 Type-A ports, so you can quickly connect more USB devices. It's bus-powered, so there's no external power adapter required.
This four-port USB Type-C hub enhances your productivity, giving you the connections you need while you work. Connect the latest USB devices, like flash drives, capture devices and external hard drives, with fast data transfer speeds of up to 10Gbps, to save time when transferring large files.
The USB-C hub also lets you extend the life of your existing USB devices - it's backward compatible with previous versions of USB devices.
The compact, lightweight USB-Type-C hub is a convenient and portable addition to your laptop. It's bus-powered, so it draws its power directly from your computer's USB-C port, with no external power required. That means fewer cables to carry with you when you travel. It also has a built-in cable (9.8 in./25 cm) for convenient travel.
The USB 3.1 hub works with a wide range of operating systems, including macOS, Windows and Linux. It installs automatically when you connect it to your laptop or desktop, so you can be up and running quickly.
Compact design
The hub features a compact form factor that makes it easy to integrate into any workspace setup, saving space while providing essential connectivity. -
Versatile connectivity
Equipped with four USB 3.0 Type-A ports, the hub offers enhanced connectivity options for multiple devices, enabling efficient data transfer and device management. -
Reliable performance
Built to comply with various USB standards, the hub ensures compatibility with a wide range of devices, supporting legacy and modern technology requirements. -
Environmental adaptability
This USB hub is designed to operate in various environmental conditions, withstanding temperatures from 0 °C up to 45 °C and humidity levels up to 80%. -
USB-powered convenience
The USB-powered feature of the hub removes the necessity for an additional power source, simplifying setup and maintaining a clean workspace.
- StarTech.com 4-Port USB C Hub, USB-C to 4x USB-A Ports, SuperSpeed 10Gbps USB 3.1/USB 3.2 Gen 2 Type-C Hub, USB Bus Powered, Portable/Compact USB-C to USB Adapter Hub for Laptop, Aluminum - Windows/macOS/Linux (HB31C4AB) - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x SuperSpeed USB 3.0
- USB powered
- USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2
- 1.58 cm x 4.3 cm x 1.7 cm
- 62 g
- Black
- 2-year warranty
- Designed For
- P/N: PEXUSB321C
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- USB powered
- Processor
- X VIA Labs VL820
- Status Indicators
- Power
- 4 x USB 3.0 Type A
- Black
- Cables Included
- 1 x USB-C cable - 25 cm
- FCC, RoHS
- 1.58 cm
- 4.3 cm
- 1.7 cm
- 62 g
- Shipping Weight
- 124 g
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 20 - 80% (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
- Designed For
- P/N: PEXUSB321C
StarTech.com 1m Blue SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.53 |
StarTech.com 1m USB 3 Cable Right Angle BK | In Stock | £7.04 |
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £7.41 |
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £9.17 |
StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £6.43 |
StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.94 |
StarTech.com 6in USB 3.0 Extension Cable | In Stock | £5.27 |
StarTech.com 3ft Slim Micro USB 3.0 Cable | In Stock | £8.79 |
StarTech.com 4 Port USB 3.0 Hub - USB-C Hub | In Stock | £29.84 |
StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop | In Stock | £42.51 |
StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White | In Stock | £25.61 |
StarTech.com 4 Port USB C Hub - C to C & A | In Stock | £26.12 |
StarTech.com 7 Port USB C Hub - C to C & A | In Stock | £65.16 |
StarTech.com 4 -Port USB-C Hub 10 Gbps - 3x USB-A & 1x USB-C | In Stock | £31.99 |
StarTech.com 3-Port USB-C Hub with LAN Port - 10Gbps | In Stock | £53.70 |
StarTech.com 3-Port USB-C Hub with SD Card Reader - 10Gbps | In Stock | £46.20 |
StarTech.com 4 Port USB C Hub - 3 USB-A/1 USB-C (5Gbps USB 3.0) - 11.2" Cable | In Stock | £42.74 |
StarTech.com 4 Port USB C Hub 5Gbps - 4x USB-A - Bus Powered USB 3.0 Type-C Hub - 11in Cable | In Stock | £25.05 |
StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub | In Stock | £109.99 |
StarTech.com 4 Port USB C Hub 10Gbps | In Stock | £114.53 |
StarTech.com 4-Port USB-C Hub, 100W PD | In Stock | £37.13 |
StarTech.com Portable 4pt USB-C Hub, 10Gbps | In Stock | £31.13 |
StarTech.com Industrial USB 2.0 Hub | In Stock | £42.46 |
StarTech.com 10-Port USB-C Hub Self-Powered | In Stock | £109.54 |
StarTech.com 7-Port USB-C Hub, Self-Powered | In Stock | £101.47 |
